Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: Shots of the rig and an easy shock relocate bracket
Old 02-06-2006, 10:11 AM   #1
Powered by Awesome
TwistedXT's Avatar
Default Shots of the rig and an easy shock relocate bracket
ok.. youve all probubly seen this before but here we go...
Here is what i started with
then i stretched the rear and centered the top mounting holes on the shocks, chopped off the front fenders and hacked the rear. I also added 1/2"x1" angle aluminum stock for rock rails and above the rear tires. (under full flex, the rear tire was grabbing the body, the aluminum rails help the tire to slide on the body rather then grab).
to relocate the shocks, i used the stock grey plastic shock inserts, 1 piece of aluminum C channel and drilled some holes so the stock shock mounts would hold it tight to the body, then,... off to ace hardward, where i picked up 2 nylon bushings that fit inside of the stock shock loop and 2 nuts/screws and washers to hold it all together.... Bolted it all together and whala! Lots 'o' flex!
And for those of you who are wonderin what i was watchin... it was on Spike TV, UFC (Ultimate Fighting Championship )
TwistedXT is offline   Reply With Quote
Old 02-07-2006, 12:18 PM   #2
Powered by Awesome
TwistedXT's Avatar
i just added pics of the shock mount LOTS OF PICS
Old 02-07-2006, 03:20 PM   #3
nice rig love the sliders and i watched the ufc fights too good noight of drinking beer adn watching 2 beat the hell out of each other
Snow is offline   Reply With Quote
Old 02-08-2006, 10:26 PM   #4
Nice rollbar, thats the first thing I did, was wrap the whole thing in electrical tape. Makes it look more realistic. At one point, I covered the whole cage with small pieces of 3/8" hose, which looked cool, but was way too top heavy. Have since removed all hose.
Toy. Runner is offline   Reply With Quote
Old 03-26-2006, 10:41 PM   #5
Nice! I wrapped my roll bar also, easier than painting and cheaper.
ToyMan is offline   Reply With Quote
Old 03-27-2006, 01:03 AM   #6
Cut the roll of black tape down the middle so it's half the width. When the roll bar is wrapped it'll look a little more to 1:6 scale as the tape is half the width and the wraps are closer. It'll take more time to wrap but it's worth it in looks! I used a VERY sharp knife and cut it down while it was still on the roll.
cj4qts is offline   Reply With Quote
Old 07-09-2007, 09:22 PM   #7
Default inboarding rear shocks..?
by relocating the top of the rear shocks inward that little bit.. does it make that much of a difference..
Bruce
jeep_freek is offline   Reply With Quote
