Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: Frequency list.
Old 02-06-2006, 11:42 AM   #1
06 Super National Champ
JasonInAugusta's Avatar
Default Frequency list.
Below are the channels and corresponding frequencies.
Channel 1: 27.075 MHz
Channel 2: 27.105 MHz
Channel 3: 27.135 MHz
Channel 4: 27.165 MHz
All that happens when you flip the switch is that you change the VCO (U1)
I have the schematic (not the block diagram that's below) in .pdf format if anyone wants it.
JasonInAugusta is offline   Reply With Quote
Old 02-06-2006, 08:23 PM   #2
I want it!
Man I couldn't type that fast enough... I musta typo'd three times tripping over keys...
Where'd you find it? I want to start using that fourth function...
vlmarshall is offline   Reply With Quote
Old 02-06-2006, 09:27 PM   #3
4th function?
I assume you're talking about the ATS308T?
Steering is 1
Throttle is 2
Steering trim is 3
Throttle trim is 4
The trims are referred to as "offset 1" and "offset 2" in the schematic.
Anyway...here's the schematic: http://www.projecttwin.com/files/nylintschematic.pdf
Old 02-06-2006, 09:41 PM   #4
No, not the trim, there's another(but unused) function, like the hi/lo switch.
Old 02-06-2006, 10:08 PM   #5
You'd better start designing the input circuit to make it work then!
Check it out:
https://gullfoss2.fcc.gov/prod/oet/c...ledFromFrame=N
In the top block type in O2D (that's Oh two Dee)
Then type in FUNRISE-61T in the 2nd block.
Enjoy.
