| | #1 |
| Newbie Join Date: Jan 2006 Location: Chesapeake Beach
| I know I've read that the bottom and top links should be the same length for optimum articulation. But, what if you're using bent links for the lower 4 links for more ground clearance? Are the upper and lower links supposed to still be the same length? Or should the lower links be slightly longer, since they are bent? |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Sep 2005 Location: Rapid City
| Just measure end to end, not along the bend. It doesn't change the geometry if theyre bent. |
| | #3 |
| Rock Crawler Join Date: Sep 2004 Location: a place of settlement, activity, or residence.
| This is probably the best thread for setting up 4-links I have seen. Should have all the info you need. 4-Link 101? |
| Thread Tools | |
| Display Modes | |
