06-22-2010, 12:25 AM | #1 |
Rock Crawler Join Date: Sep 2004 Location: eureka
| Bodyless chassis , Formula toyota design(not tube)
Ive always wanted to make a scale 1.9 f-toy but I have no work area or skills to do any brazing. I was looking at some comp rigs that run the bodiless tvp chassis, and thought maybe i could make a f-toy style one for my scale rig. drew it up in sketchup to get an idea of what it would look like. I think it looks decent , but im not sure that the roof bars would hold up. The material I want to use is of derlin, mabey 1/8'' thick? any ideas on thickness to get enough strength ? heres some pics: |
06-22-2010, 05:17 AM | #2 |
Rock Crawler Join Date: Mar 2006 Location: North Carolina
I've been playing with this ideal my self for a jeep. I think 1/8 would be fine, just add a little material here and there around your holes. Looks good. |
06-22-2010, 09:22 AM | #3 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
06-22-2010, 09:40 AM | #4 |
06-22-2010, 03:23 PM | #5 |
RCC Addict Join Date: Nov 2005 Location: Kansas
06-23-2010, 12:11 PM | #6 |
Rock Stacker Join Date: Oct 2009 Location: santiago, Chile
Nice chasis Dude. I am drawing something like that to make it in 6mm. technyl. For your chasis I have some ideas: - Can you make an "X" frame to cut, so you can use bolts to fix it making a diagonal reinforsment, just behind the tranny area? It will give more strengh to the chasis. - the front area will allow a lipo pack or a Nicd Battery? It seems to be a little small for the second one. The rest looks awesome! |
06-23-2010, 11:32 PM | #7 |
the area im most concerned about is the front roof area. all the bars are 1/8'' material and 1/4'' wide . I have to make the chassis as wide as possible without the tires rubbing, ( in order to get a semi scale look to it, sense it wont have fenders and stuff covering the tires like a real f-toy would be like) so i figure around 3-3.5 inches wide which will be plenty of room for a the battery I will be using Which is just your normal axle sub-c split battery pack. In a side by side configuration like in this pic: (the little support bars are going to be bigger, and im going to make some of the areas around bolts bigger wb is at 11.5'' Last edited by yoda316; 06-23-2010 at 11:34 PM. |
