What lube/oil/grease do you use for your rig? Hey guys just after some info on what you guys use on your rig? Mines an axial scx10 I use team losi 30,00wt diff oil inside my diff gears.. I use Highspeed car grease outside my diff gears.. I pack the whole diff with it..Been running for 3months now seems good.. For my bearings,screws,cvs,dogbones,driveshafts etc etc..I use protecta lube http://www.pacificrimdistributors.com.au/protecta.htm I also spray a drop on my motor on both sides.. So what do you guys use? |
I use Rocksmith Gear Jelly on any of my metal gears and Tamiya white lube on my rigs with plastic gears. For shocks I use Associated Synthetic shock oil and for diffs I use OFNA Diff lube. |
rocksmth gear jelly and i use losi shoc oils and cow rc cleaners |
http://www.philwood.com/wp-content/product/grease.jpg Readily available at any bicycle shop worth it's salt. Narly1 |
I use Losi shock oil in my shocks, Associated clear and black lubes for the diffs. I also have used CRC engine assembly lube (I had a large tube ) I think it is the same stuff as Associated Black lube. Then I pack it all with water-resistance Marine grease :shock:. So I guess that cancels it all out. |
I use vanquish star lube in the berg cases and Losi shock oil in the....well shocks :mrgreen: |
Pedro's Syn-Lube and Tri-Flo. Both hold up very well and are easy to find. |
I use Mobile 1 synthetic gear lube (bearing grease) for trans/diff/tcase gears. Shocks get whatever oil I have. I think I've got some Losi, Axial, Associated, Ofna, Mugen. Some of the "shock" oils I use are actually light weighted diff oil...to get some heavy weighted shock oil. :) |
Rocksmith Gear Jelly goes on all my ring and pinions, and in my transmissions. Great stuff. "thumbsup" |
i use lucas ball bearing grease in my diffs, and trannies. 10-20wt oil in my shocks with losi gold springs |
I used to use gear jelly but now just use red silicone grease. Haven't seen much/any difference? :???: For shock oil what ever brand that's cheapest & available. Again can't tell a difference? :???: Just don't use automotive petroleum based products. They can mess the plastic up! :sad: Oh and tri flo is one of my favorite things! Great in cvds/300s! |
Losi shock oils and "Lucas Red and Tacky 2" for gears. |
Is it safe to use white lithium grease? That is what the guys at my LHS recommend. |
I used castrol marine lithium grease on my scx10 packed the whole diff full and dipped all my bearings now it's smooth and I can do heaps of water crossings:-) |
Castrol LM lithium. About $5.00 / liter so you can use it with abandon, fill gearboxes and diffs till it squeezes out. It's almost too good for my rig! :ror: Shock oil is the cheapest I can find, as long as it's weighted. It's only gonna leak out, get spilled on the rocks or thrown out when I change the weight. Why waste money on a branded product? Cheers. |
My R2D has been going through gear sets every 20th battery or so. It's set up with a 3S lipo, Sidewinder, & a HH 35T Torquemaster I've been using some blue Mobil grease (not sure of the name), but I think it is too thin. Her's hoping that Gearjelly will solve this issue! RockSmith's Site |
Gorilla Snawt grease and what ever shock oil i have in me tool box that's the right weight. |
i use grim racer speed grease on my bully and rs10 works great for steel and plastic gears, NEVER had a problem with it been using it for years dosent sling off and is nice and tacky:ror: |
