Thread: broken beadlock ring
Old 02-26-2006, 03:33 PM   #1
Default broken beadlock ring
i noticed today i have a broken beadlock ring. is this a common breakage? i broke more stuff today also, may have to buy a new chasis as i hear the customer service is backed up pretty bad
bmf24 is offline   Reply With Quote
Old 02-26-2006, 05:11 PM   #2
i couldn't belive it when i heard about it the first time, i checked mine out and 2 were cracked so i put so superglue on them and the put some washers in the wheels like rock rings and i'm good to go. so yes it is commen to break the rings. what did you break you may be able to fix it. consider youself lucky, we don't have them in stores in canada so i have to use customer service or go back to the states to get another one.
4runner666 is offline   Reply With Quote
Old 02-26-2006, 06:31 PM   #3
i broke the knuckle. and there is a nasty noise comming from the rear.
the knuckle is still good as long as you dont load it hard. if i get into cracks and stuff the knuckle will slip.
Old 02-26-2006, 10:42 PM   #4
[HOONIGAN]
Wrecker's Avatar
yeah, breaking rings is common. superglue it back on there and you'll be good to go, except for the knuckle, JB Weld "might" be a good band-aide untill you can get it replaced.
Wrecker is offline   Reply With Quote
Old 02-27-2006, 03:46 PM   #5
I have one that is cracked.
rm25x is offline   Reply With Quote
Old 02-27-2006, 05:59 PM   #6
i want to know how you guys are busting them.....my Nylint has taken some seriously hard tumbles (on both dirt and rocks) and they aren't broken....one roll was from about 6 feet up a concrete wall, and it landed on the passenger side rear ring.....no breakage....
another was from about 30 feet up a dirt hill, rolled about 25 times before it stopped .....no breakage :?
maybe i just have a freakishly strong nylint
SlammedMini469 is offline   Reply With Quote
Old 02-27-2006, 09:16 PM   #7
Mine has never been outdoors, and never took any tumbles. Has only laid on its side a couple times.
Old 02-28-2006, 12:23 PM   #8
Post
if you dont break something your not doing it right!! i have broken pretty much everything on the damn thing!!
slammed if you havnt broke it let me play with it i am sure i could break something!!
adawg69 is offline   Reply With Quote
Old 03-02-2006, 01:42 PM   #9
i got this on x-mas. so far i have broken both axle pins, a knuckle, beadlock, rollcage, and the rear needs some serious work. i am going to take somestuff apart tonight and see what i find.
but for $150 toy, it has been woth every penny.
Old 03-03-2006, 01:27 PM   #10
I thought you guys were crazy too, saying you were breaking the beadlocks, as I had beat on mine pretty hard, and didn't have any break. Then my buddy bought one, and within just a few days, two of his beadlock rings were peeling off really badly. So I cleaned up my wheels and looked harder at mine, and sure enough, three of mine were cracked and starting to open up. So I looked at my wifes crawler, and all four of hers were cracked, one pretty bad. It almost appears though that even with that ring missing, the tires would still stay on just fine because of the way the inner wheel and tire is made. Someone correct me if I am wrong.
mudking82 is offline   Reply With Quote
Old 03-03-2006, 03:29 PM   #11
One of mine cracked. I emailed Nylint and Steve got back to me the same day. 4 new tires and wheels arrived within a week.
basalt51 is offline   Reply With Quote
Old 03-03-2006, 03:39 PM   #12
damn, i have called, send e-mails, and have never heard back from anyone.
