Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: New tech article added.
Old 02-01-2004, 07:46 PM   #1
It's a setup!
jason's Avatar
Default New tech article added.
Thanks to Matt and Adam from Monstertruck parts!
For the rest of you that have submitted articles keep checking back, I've been busy.
http://www.rccrawler.com/article-5--0-0.html
jason is offline   Reply With Quote
Old 02-01-2004, 08:00 PM   #2
Highmark's Avatar
Default Re: New tech article added.
Very nice article-I perosonaly prefer glue or sofren iron to lock diffs.
Can you say twinkie?
Highmark is offline   Reply With Quote
Old 02-02-2004, 03:05 PM   #3
I use hot glue exclusively and have never had a diff let go. Not only that but you can use it 15 minutes later.
zBigBadWolf is offline   Reply With Quote
Old 10-21-2006, 12:58 PM   #4
I would like to see what the artical said. But the link is dead.
I'm justing see how things progressed for the past couple of years.
RESEARCH
Double J is offline   Reply With Quote
Old 10-21-2006, 01:09 PM   #5
i used some stuff i got off ebay for locking my diffs, so far no probs. its plasti somthing or other, got it from the uk for on site plastic repairs, molding and other stuff. you heat it up, either with a lighter or hotwater, i used water and the plastic balls get soft and moldable, then i jammed as many as i could into the spider gears, holding them together so it didnt push apart. if any ones interested i'll see if i can find the seller or a link.
Thorsteenster is offline   Reply With Quote
Old 10-21-2006, 02:09 PM   #6
The article is still there, just go the the actual RCC home page, and click the link for tech articles.
todd1803 is offline   Reply With Quote
Old 10-21-2006, 05:15 PM   #7
It's a setup!
jason's Avatar
RESEARCH
http://www.rccrawler.com/txtdiff.htm
