![]() | #1 |
Newbie Join Date: Jan 2006 Location: Walla Walla
I broke the peace of the knuckle that the axle goes into. How do you get the knuckle off of the axle and what do you use to fix it. ![]() |
![]() | #2 |
Quarry Creeper Join Date: Jan 2006 Location: PNW
which side? If its the driver side take a pair of dykes or side cutters, and kind of pull the pin out of the pitman arm. Once you get it kind of out alittle bit you can use pliers to finish pulling it out. From there it just comes off. Well if you take the covers off the axles should just pull off then. Basically just start removing screws and you'll see how it comes apart. |
![]() | #3 |
Thanks ![]() |
