10-26-2010, 09:54 AM | #1 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
| Really long drive shaft.
Hey all I need a really long drive shaft the suit axial Tranny and dif. Its to go in a 60/40 slingshot. It needs to be around 140-150mm long. Have you guys in the know got any suggestions for an off the shelf shaft or will it have to be a home brew drive shaft. I have looked in to a junfac but the longest they go is 130mm. Cheers Last edited by Highlucks; 10-26-2010 at 09:58 AM. |
10-26-2010, 10:03 AM | #2 |
The Punisher is made in quite a few longer lengths: http://store.rc4wd.com/Punisher-Shaf...ole_p_813.html The longest they have is listed as 237mm extended....so I am sure you can find one that will work. |
10-26-2010, 10:05 AM | #3 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
I would just piece one together using male and female 'Pede shafts. Yea, it's plastic, but leaving the male parts long inside the females will improve the strength, and it will be light. If your set on a metal one, and have a welder... you could extend a steel shaft out. Junfac, MIP, etc. Or the long punisher shaft available as per Jeremy's post above. Here is a shot of a Pede shaft I put together: Last edited by gunnar; 10-26-2010 at 10:07 AM. |
10-26-2010, 10:13 AM | #4 |
Yep, that's how I used to build them for my scalers before people started making metal shafts. Never really had an issue...
10-26-2010, 10:42 AM | #5 |
Quarry Creeper Join Date: Apr 2010 Location: Natchez
The pede shafts have held up well for me in the past. They are strong. I have used them on a few different rigs now and haven't had any trouble.
10-26-2010, 10:49 AM | #6 |
| Yep, the only trouble I've ever had with them is the ears.....with those metal u-joints, I'd just break or twist the ears.
10-26-2010, 07:22 PM | #7 |
Sweet thanks guys, I had forgotten about the punisher range. Pede shafts it is to keep the back end nice and light.
