12-04-2010, 10:03 PM | #1 |
Newbie Join Date: Nov 2010 Location: So Cal
| Need help with servo mount
I bought a used RCP Hustler Super with Clodbuster. I was out crawling today when the rear servo mount broke. The servo mount came in two pieces. The smaller piece is bolted onto the axle and the bigger piece, which the servo is mounted to, is then bolted onto the smaller piece. I've been searching for the last hour but can't seem to find the mount. Help plz. Thx. |
12-04-2010, 10:23 PM | #2 |
Pebble Pounder Join Date: Jul 2010 Location: Oregon
Pics would help. Their is alot of places out their to get clod servo mounts. Tcs, rpp, rcp, ckrc, Crawford performance. One of those places should have what your looking for. Hope you find it
12-05-2010, 01:16 PM | #3 |
Thanks
12-05-2010, 02:25 PM | #4 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
If you buy my servo guard - servo mount - servo clamp and turn it upside down you can use it as a mount for your clod. Just attach it to the stock axle tube brace. It is made from T6 6061 Aluminum and manually machined by a professional machinist and made here in the U.S.A. This part serves two purposes. First it protects your servo from rock rash and abuse, but it is also a clamp to securely hold / mount your servo in place. These are available on my web site if you would like to order your own: http://www.crawlerinnovations.com/ Here is the proto type I have been running on my Rock Show Berg for the last six months. As you can see from the picture, it has taken it's share of abuse and properly protected the servo while doing it. |
12-05-2010, 06:38 PM | #5 |
That is similar to my servo mount except that I'd need to drill two holes to mount it on the the bracket that is bolted onto the Clod. Thx. |
