12-05-2010, 11:46 PM | #1 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
| Transfer case with disconnect
Project Scale 4 Runner. Looking for a transfer case with or without reduction that has a 2wd / 4wd disconnect DIG option Is it available or is somebody going to build one ? Wan to place motor under hood mated to two 4 to 1 reduction units drive shaft to transfer and have the transfer disengage the rear. |
12-06-2010, 09:58 AM | #2 |
Quarry Creeper Join Date: Aug 2008 Location: 5280'
the Losi Comp Crawler trans works for a t/case. you can go from 2wd/4wd/front dig, but it will not lock the disconnected drive shaft. because they are for worm axles that do not freewheel. if you can make a brake type thing on the drive shaft the trans would work great. |
12-06-2010, 01:35 PM | #3 |
Cad2Chrome use to make one, actual transfer case with selectable 2/4wd. Just checked his site and says out of stock so you might have to dig around for one but its out there. Other then that the LCC seems like the choice for most. |
12-06-2010, 02:22 PM | #4 |
I wanna be Dave Join Date: Oct 2008 Location: Golden
Why not just use an axial trans with dig? I did that on my LJ Mutt build... Had the motor under the hood with a touring car spur gear (5mm shaft) then just trimmed down the input shaft on the transmission (also a 5mm shaft). Works great! Still, kind of wish this type of thing was available in a more scale design, tough thing is it would be probably fairly bulky. |
12-07-2010, 09:05 PM | #5 | ||
I want my transfer case to be where it should be DIVORCED and select disconnect rear Motor under hood then reduction unit to short drive shaft to reduced tranny and short drive shaft to transfer | ||
12-07-2010, 09:07 PM | #6 |
Rock Crawler Join Date: Oct 2009 Location: Wasilla, Alaska
Losi Comp Crawler |
12-07-2010, 09:34 PM | #7 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
rc4wd transfer case on an axial tranny...just replace with R2 tranny and your good... |
12-08-2010, 02:46 AM | #8 | |
In this set-up, the motor is divorced from the case, mounted to a gear reduction unit, which then has a 5mm shaft to connect to a driveshaft to connect to the input shaft trans case (where the spur normally mounts to) Not sure if I have pics of this, but I can look tomorrow. | |
