| | #1 |
| Newbie Join Date: Feb 2006 Location: East Central
| I have spend the last 3 days searching for this answer, came up with lots of information but nothing on my problem. All of a sudden my scorp will not go forward. Neither the front or rear axle. It goes fine in reverse but does nothing when i try to go forward. I have replaced the batt in the controller, charged the battery pack, put in another 7.2v battery pack in. Still nothing. Took controller apart and did not see anything wrong, metal piece is contacting the connection for forward but not going anywhere, Anyone know where to check for this? past the 90 day warrenty, so if can't find the problem. i'll be switching to hg electronics. Thanks in advance for any help. |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Aug 2005 Location: classified
| I've had the same problem aswell as many others here. I searched for "throttle" and came up with this very informative thread for you. Finally Btw, all you have to do is stretch the throttle spring a little to make better contact with the board. Last edited by Lt. Dan; 03-23-2006 at 02:35 PM. |
| | #3 |
| Thanks for the info i'll look into that tonight when i get home. Though last night when i had the controller apart i took that metal piece and moved it to the reverse contact and the truck moved. then moved the meatl piece to the forward area and still nothing. Let ya know what i find out. |
| Thread Tools | |
| Display Modes | |
