Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: I Heard It, The Crackling
Old 03-23-2006, 05:27 PM   #1
Default I Heard It, The Crackling
well it finaly happend,got the rear tire stuck nd the axle still wanted to go and then i heardthe CRACKLE. i dont know if somthing stripped or the metal thing moved.i have yet to take it apart.it still works so i dont think anything stripped.
twisted is offline   Reply With Quote
Old 03-23-2006, 07:43 PM   #2
Sounds Bad Eh
Inclodneato is offline   Reply With Quote
Old 03-23-2006, 09:30 PM   #3
Mine also does this but it still works fine
plyr2k is offline   Reply With Quote
Old 03-23-2006, 09:54 PM   #4
Not for long....mine did it a few times and then I pulled it apart to see if the glue on the metal part came loose, nope. Half of the gear was stripped and a few teeth were gone.
TxCruzr is offline   Reply With Quote
Old 03-23-2006, 11:07 PM   #5
so after doing some searching i take it shimming the outer part of thaaxle to keep the axle from walking back and forth and bending the tabs down on the metal "dog" will fix the problem ?
Old 03-24-2006, 12:02 AM   #6
ok i shimmed the yellow gear on the shaft to try to get some of the wobble out,it did little to help that,i think what needs to be done there is some type of sleeve or bushing/bearing. i then glued the yellow housing to the metal part.
after that dries i will see about the axle alignment but i think thats all in the wobble of the yellow gear.
Old 03-24-2006, 03:34 AM   #7
knock on wood, i've yet to hear bad axle noises.
i'm running 2.2s, which i have not glued to the rims. they only seem to slip (poor man's clutch?) under the most severe of conditions, which maybe is helping keep my gears alive. i've only lost a bead a few times, and usually only after a tumble. every time i read an axle issue thread, i talk myself out of gluing them once again...at least until nylint makes replaceable gear sets for these things.
superelmer is offline   Reply With Quote
Old 03-24-2006, 06:18 PM   #8
Predator micro motors
getbent's Avatar
When my axle started clicking I shimed the axle shaft to keep it from wandering side to side causing the gears to line up by only a half a tooth. This lined the gears up much better and then I used the tape method to push the motor harder against the gears. If you need I can take pics.
getbent is online now   Reply With Quote
Old 03-24-2006, 11:48 PM   #9
i understand the shim part on the axle but whats the tape on the motor for ?
Old 03-25-2006, 01:55 PM   #10
getbent's Avatar
Ypu don't actually put tape on the motor, rather on the gear boxes where they sit in the case to help push the gear box more towards the axle gears and take away any slop. I'll post some pics later tonight.
