Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: Help I Need Info On Axle!!!!!!!
Old 03-24-2006, 06:03 PM   #1
Default axle not moving HELP!
HELP!!! my front axle is screwed up when i go forward and turn the wheels they lock up and its only the front that lock up! HELP ME!!!!
daven75 is offline   Reply With Quote
Old 03-24-2006, 06:09 PM   #2
Predator micro motors
getbent's Avatar
Mine did the same. I don't really know what fixed it, but I took it all apart, lubed it and put back together. No more problems.... go easy on the lube though, dirt magnet.
getbent is offline   Reply With Quote
Old 03-24-2006, 06:18 PM   #3
well i'll try that unless anybody else has any ideas.
Old 03-24-2006, 08:54 PM   #4
i tryed the lube thing but it didn't work any 1 else have an idea?
Old 03-24-2006, 10:55 PM   #5
its gotta be somthing in the knuckles binding the axle up. i mean if its only happening when its turned that where the problem should lie.it is only when you turn rite ? or is it when you go forward too with out turning the wheel ?
twisted is offline   Reply With Quote
Old 03-25-2006, 08:57 AM   #6
no its only when i go forward and turn.it also does it when im in reverse and turning.
