Thread: Ax10
Old 01-04-2011, 08:43 AM   #1
Default Ax10
Just got a AX10 off ebay coming. Still need a speed controller and radio. So it looks like the mamba max is a good all around one. Any others I should look at?
landmissle is offline   Reply With Quote
Old 01-04-2011, 09:30 AM   #2
First, look in the electronics section of the forum ;)
Maybe sidewinder depending on how much space you plan to have, how many Volts you plan to run, and what motor you plan to run.
Also, the Holmes Hobbies stuff gets great reviews and is comparable to the Castle stuff.
You really should just read up as there is a TON of info on this forum.
chevy42083 is offline   Reply With Quote
Old 01-05-2011, 09:01 AM   #3
here you can find all aboud electronic!!
http://www.rccrawler.com/forum/electronics/
k20man is offline   Reply With Quote
Old 01-07-2011, 12:41 PM   #4
you might want to look at the tekin fxr its small and could save you alot of room
txcrawl is offline   Reply With Quote
Old 01-07-2011, 12:57 PM   #5
Default fxr
FXR is great and small you can run 2 and 3 s and i here of people running 4 s to.
wurster is offline   Reply With Quote
Old 01-07-2011, 01:30 PM   #6
Go castle creations. The mamba micro pro, sidewinder micro, sidewinder, and so on. The sidewinder micro is small, handles 3s, and is good for motors up 35t. I think they are around 60bucks.
Edit: found it
65bucks
If you want to see a pic go here> http://holmeshobbies.com/product.php...6&cat=2&page=1
Cells 4-12 NiCad/NiMH or 2-3 LiPo
Continuous Current 35 amps
Resistance 0.045 ohms
Programmable Low Voltage Cut-off
ESC: 0.95 x 1.72 x 0.4"
0.9 oz (24.5 g)
1.5 amp BEC
3.5mm female motor plugs installed
Jeepkid is offline   Reply With Quote
Old 01-07-2011, 03:45 PM   #7
I'd just go with the holmes BRXL. Similar footprint to the sidewinder, can be had for about $80, and it's good for up to 6s lipo, and has a monster built-in BEC (6v, 5A)
Plus JRH is an awesome guy and his service is top notch!
version_three is offline   Reply With Quote
Old 01-08-2011, 08:31 PM   #8
Default ebay
was it the ax 10 with the integy cage,
chase1deer is offline   Reply With Quote
Old 01-09-2011, 12:03 PM   #9
I love ebay.......some times lol
2manyprojects is offline   Reply With Quote
