Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: Mounted up some spare TLT tires
Old 03-26-2006, 11:38 PM   #1
Default Mounted up some spare TLT tires
Here's some shots of my streched scorpion with my spare TLT wheels and tires, TLT shocks are considered junk by some, I'll mount them and see how they do.
The rims and tires look pretty good and the way I mounted the adapters It'll be easy to swap on some bigger ones later. I'll try and post some action shots as soon as the rain goes away.......
I used a soldering iron and a hex bit the same size as the nylink hex, and some spare wheel adapters that come with HPI rims to make the adapter. I drilled the center with a 1/4 bit, then quickly burned the hex into the adapter. They're a standard 12mm hex so most rims will now bolt on.
Press into the adapter
done
FlexinTLT is offline   Reply With Quote
Old 03-27-2006, 12:02 AM   #2
thats sick and a great idea Click the image to open in full size.
plyr2k is offline   Reply With Quote
Old 03-27-2006, 07:51 AM   #3
thats awsome can u tell us how to do it in a little better detail?
daven75 is offline   Reply With Quote
Old 03-27-2006, 08:53 AM   #4
I believe that he just bored up the hex adaptors.
Nice work, man!
mt_power is offline   Reply With Quote
Old 03-27-2006, 01:51 PM   #5
Heres a little more detail of how I made the adapters. I'm at work so no pics.....
Hpi rear truck wheels come with 12mm off set adapters for different models. Take those off the plastic trees and drill the hole in the center of them out bigger to 1/4 inch. Take a hex bit the same size as the nylink hex (5/32 I think), pull out the tip on your soldering iron and put the hex bit in so it heats up. After you have enlarged the holes on the wheel adapters with the 1/4 drill bit, place the adapter on something flat and press the heated hex bit through the hole. (do it quickly so you dont melt the adapter, it will litterally be like a hot knife in butter). This will burn the hex shape into the adapter.
Old 03-27-2006, 04:46 PM   #6
is it a nice tight fit and do you get full steering form lock to lock ?
twisted is offline   Reply With Quote
Old 03-28-2006, 12:21 PM   #7
The hex was almost the exact size as the nylink hex. The adapter is a snug fit, and the rims have enough off set to not interfere with the steering. Regular 2.2 rims (not TLT like mine) might not have enough back spacing to clear the steering turnbuckle.
Old 03-28-2006, 07:53 PM   #8
thanks for this idea...im gonna steal it. lol i have some tlt tires and just got some traxxas hexes as they didnt have any hpi ones.
