Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: is it possible to climb stairs with the 1/6th?
Old 03-27-2006, 11:55 PM   #1
Default is it possible to climb stairs with the 1/6th?
Noob in the house, just picked up my 1:6 jeep and did the rear shock mounts and extended the wheelbase in front and rear, know what? I want to be able to climb up normal house stairs is it possble with out alot of modifications?
foxsuperduty is offline   Reply With Quote
Old 03-28-2006, 01:56 AM   #2
in order to do that.. U have to do a tummy tuck, and prob set a pop can or somehting on the front for weight to keep the front end down..
Muddinguy is offline   Reply With Quote
Old 03-28-2006, 10:26 AM   #3
You would have to do a tummy tuck like Muddinguy said and also you would have to extend the rear out and out board the motor in the rear and shave the rear axle. So basically you would have to mod it really good to have it just walk up stairs.
Mr. Chevy is offline   Reply With Quote
