Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: 9 inch strokers
Old 03-28-2006, 02:48 AM   #1
Talking 9 inch strokers
No pretty paint here. Just a tummy tuck, body bob, extended wheelbase, and 9 inch long shocks for near 90 degree articulation.
MtnCrawler is offline   Reply With Quote
Old 03-28-2006, 10:01 AM   #2
Thats FREAKIN SWEET ....... my 2cents cut the tire... besides that, that thing rocks
CreepyCrawler88 is offline   Reply With Quote
Old 03-28-2006, 04:43 PM   #3
Uhh.....where'd you get the shocks?
fatexassk5 is offline   Reply With Quote
Old 03-28-2006, 07:26 PM   #4
Fawk shocks, near 90*, its all bout the FULL 90.
CaddyBYota is offline   Reply With Quote
Old 03-28-2006, 08:13 PM   #5
90 is WAY too much artic. About 60-70 is good for crawling. Any more than that and you'll get twisted up in a hole and you can't get back out.
Crawlerguy851 is offline   Reply With Quote
Old 03-28-2006, 09:00 PM   #6
yeah, but dude. 9 inch shocks, i bet it does sweet on a ramp.
bobbo27 is offline   Reply With Quote
Old 03-28-2006, 09:18 PM   #7
Thanks for your expert scientific evaluation. I'd like to review your calcs confirming that 90 degres is WAY too much articulation. These spring keep the tires in firm contact with the ground whereas your mere 70 degrees is sure to lift a tire or two when it gets twisted up. Maybe you should look into another less calculating career.
By the way, the springs are stacked FIRM BLACK HPI SAVAGE 4.6 SHOCK SPRINGS over new rods and tube casings from where else - Home Depot. The shock tower is just bent brake line anchored by the stock horseshoe shock clamp.
Old 03-29-2006, 08:23 AM   #8
Oh Lord, here comes a can of worms. I guess you are both right. There are situations that 90 degrees of articulation will be helpful. However, those situations are very few. Most of the time, it will only make the vehicle less stable. I must agree, it does look cool and will impress people.
jeepinmatt is offline   Reply With Quote
Old 03-29-2006, 11:08 PM   #9
1 man, 2 sons
Unimoger's Avatar
looks like it belongs at moab.
Unimoger is offline   Reply With Quote
Old 03-31-2006, 07:22 PM   #10
thats supposed to look cool?
bmf24 is offline   Reply With Quote
Old 04-01-2006, 10:41 AM   #11
No.......................
this is....
Old 04-01-2006, 10:53 AM   #12
Looks like the shock rod popped out.....:?
if you think weight/gravity-wise, a full 90 flex will have all the rear weight on the side of one tire, or just the corner. That won't be very effective.
muddeprived is offline   Reply With Quote
Old 04-01-2006, 07:35 PM   #13
mine kept falling apart like that and i ended up bending up both rear springs pretty bad. not to mention it was very anoying to have to fix the shocks every time it flexed a little. this time i made limiting straps. mine flexes plenty and stays stable on side hills.
i had mine set up with the shocks set stock location and inboarded for more flex. i tested them on the same rocks using the same paths and found the rig works better with the shocks in the stock location and less flex. either way it went the same routes, but in one spot the inboarded springs kept rolling the jeep.
when i extended the rear wheelbase i found it just plain sucked. first, with the rear sticking out further the wheelhop was insane. it didnt climb for crap. i was not impressed. so now it has cut up shocks in the stock locations and the axles it in the stock loaction. next i am looking at cutting the center, and maybe moving the rear motor. not sure on the rear though, it doesnt give me a ton of trouble, just a little. not like the front.
