03-27-2006, 05:45 PM | #1 |
Newbie Join Date: Mar 2006 Location: Sacra
| Run in the Rocks Last edited by TwistedXT; 03-29-2006 at 11:16 AM. |
03-27-2006, 07:39 PM | #2 |
Pebble Pounder Join Date: Dec 2005 Location: Fort Worth! Need a Address??
That thing must flop easy and slam some axles down without springs. BTW how did you get the center pins out of the axles??
03-28-2006, 12:06 AM | #3 |
It actually doesnt flipp that much, its all bout tire placement. The only thing bad i have found with no shocks is the frame sit a little low. But, its cool for what i like doing. As for the pin, well my front axle housing broke so it poped the pin outta the axle, then i just tacked a nut to the end of the exposed pin . The heat from the tack let me pull it right out with some pliers. Then i plastic welded by soldering plastic tothe broken axle. |
03-29-2006, 10:09 PM | #4 |
man, that jeep is damn flexy. does it flip over easy? I mean, it looks unstable at full stretch.
03-30-2006, 05:14 PM | #5 | |
04-01-2006, 01:44 AM | #6 |
Rock Crawler Join Date: Jan 2006 Location: Dallas
yr jeep has awsome flex!looks awsome and that looks like a sweet place to crawl!
04-01-2006, 03:36 AM | #7 | |
