02-02-2011, 01:23 AM | #1 |
Rock Stacker Join Date: Jan 2011 Location: Singapore
| steel shaft pins
hi all.. i m using 2 sets of steel shaft, one set the pins keeps falling out dispite tightening, and the other set the pins broke in 2!! both front n rear!! what gives? one is from Tamiya and the other from Gmade.. is there a proper way to 'prep' the pins to hold them in place? currently i am trying threadock but am not sure if it is correct or is there a better way? pls help.. thanx Last edited by chiatw73; 02-02-2011 at 01:44 AM. |
02-02-2011, 06:11 AM | #2 |
Are you taking about the pins for the wheels hexes?
02-02-2011, 07:31 AM | #3 |
02-02-2011, 07:45 AM | #4 |
are you talking about the drive shafts that go from the transmission to the f and r axles? if so thread locking the grub screw and put some heat shrink tubing around the shaft where the pin goes in to help keep it in
02-02-2011, 09:44 AM | #5 | |
how abt rubber drive shaft boots? think they'll work? | |
