02-19-2011, 03:56 PM | #1 |
Newbie Join Date: Jan 2011 Location: columbia
| axial
ok if this is the wrong section please move it but i am having problems with the rear drive shaft and the input shaft on the rear end. under strain the drive shaft just spins on the the input shaft. i tried tighten the allen screw on the driveshaft but it wont hold. thanks for the help guys.
02-19-2011, 04:08 PM | #2 |
is it on the flat spot? take out that grub screw, replace with a new one, and make sure to put thread lock on it. saw your location is columbia, columbia MO?? |
02-19-2011, 04:09 PM | #3 |
• Inspect the input shaft of the axle, make sure that it isn't rounded. • Recommend getting another set screw. - Clean the input shaft with some isopropyl alcohol - Clean the bolt hole that the set screw goes in to the same way - If you can't get a new set screw, clean that too • Get some blue loctite - With everything clean/new, put a drop of the loctite on the set screw - Screw the set screw in half way - Put the drive shaft on the axle and tighten down the set screw, ensuring it the set screw is making contact with the flat part of the input shaft - Before you run the truck, let the loctite set up over night ... yup, this should be in the AX10 section. |
02-19-2011, 04:13 PM | #4 |
| axial
thanks guys i had it on the flat spot but it is still just spinning. blue loctite and clean it input shaft. also is the a hardware store that i may be able to pick up a set screw?
02-19-2011, 04:26 PM | #5 |
Rock Crawler Join Date: Aug 2009 Location: I'm a michigan boy can you feel that!
You might be able too get a set screw from the Hardware store, i know the one by me has some. take yours there and ask if they sell them.
02-19-2011, 04:51 PM | #6 |
thanks man i will try that.
02-22-2011, 01:01 PM | #7 |
Newbie Join Date: Jan 2011 Location: Deltona
I had the same problem today. Gonna go to the store and see if I can get some new set screws.
02-22-2011, 01:40 PM | #8 |
Quarry Creeper Join Date: Oct 2010 Location: Ukraine
You can use cianopan glue or chinese super glue, whatever is the name for it out there. That will help. At least it works here lol
