Thread: how to stop springs dislocating?
Old 02-24-2011, 10:06 AM   #1
Post how to stop springs dislocating?
my front springs, occasionally rear, keep dislocating from the bottom of the shock.
Is this a common problem?
how to stop, is it actually worth trying to stop?
Tom94offroaduk is offline   Reply With Quote
Old 02-24-2011, 10:19 AM   #2
mine do that too sometimes. if you have adjustable shocks just bring the adjustable ring down a few threads until you are happy. if you dont want to do that try making some limiting straps. i had lost a spring retainer once but after about two hours of looking for it i finally found it
all_scaled_out is offline   Reply With Quote
Old 02-24-2011, 10:21 AM   #3
i'll have a look at some limiters, i dont have adjustable shocks ,,
Old 02-24-2011, 10:31 AM   #4
Yashua
CREEPERBOB's Avatar
THIS IS AN OPTION, JUST DRILL SMALL HOLES IN THE BOTTOM RETAINER AND HOOK WIRE THROUGH AND OVER SPRINGS AND CRIMP.
CREEPERBOB is offline   Reply With Quote
Old 02-24-2011, 10:33 AM   #5
Post
wow, good idea.
Old 02-24-2011, 12:31 PM   #6
Scaler based shock spring cups, $13.50 shipped
He makes them for different types of shocks and springs also.
hotwheels000 is offline   Reply With Quote
Old 02-24-2011, 12:31 PM   #7
I have seen others slide a small length of heat shrink tubing over the end of the spring & shrink it. This captures the end of the spring (last couple of coils) to the perch.
Charlie-III is offline   Reply With Quote
Old 02-24-2011, 12:32 PM   #8
Post
aahhh , good idea, ive got loads of heat shrink i'll look into it.
Old 02-24-2011, 02:45 PM   #9
Even those will come undone.....The drilled hole with zip tie works good.
fa1rch1ld is offline   Reply With Quote
Old 02-24-2011, 02:46 PM   #10
Old 02-24-2011, 02:48 PM   #11
x2 for JeepinDoug's cups! They work great.
killswitch is offline   Reply With Quote
Old 02-24-2011, 03:40 PM   #12
The only way jeepindougs spring cups come off is if the rodend comes off or your shock shaft breaks. His spring cups are awesome, and look better than wired on cups. IMO
456heinbach is offline   Reply With Quote
Old 02-24-2011, 04:35 PM   #13
i had a similar prob running mini t springs so i ca glued the cups to the rod end because i kept losing cups
murderface is offline   Reply With Quote
Old 02-24-2011, 04:46 PM   #14
Ive ran the Jeepindougs cups for over a year...Every course the fronts pop
off..My tires just unscrew the springs way to easy...Maybe its just me...
They are a cool product if they work for ya.
Old 02-24-2011, 04:55 PM   #15
I have had the same issue to be honest. My springs popped off pretty easy with the jeepindoug c-cups so I went with shrink wrap and had zero issues ever since. I like that idea of drilling the cups and using wire.
DRCrawlGood is offline   Reply With Quote
Old 02-24-2011, 05:37 PM   #16
Or just bend the last coil of the spring a bit tighter so it grips the cup. Free, easy, simple.
Manning is offline   Reply With Quote
Old 02-24-2011, 05:39 PM   #17
The springs... they can't BE STOPPED!!!
wonder squirrel is offline   Reply With Quote
Old 02-24-2011, 05:53 PM   #18
I double the heat shrink trick just make sure it covers the cup and about 2 coils of the springs and your good to go.
Boids is offline   Reply With Quote
Old 02-24-2011, 07:03 PM   #19
Small drop of thin ca on the end of the spring cup and slide the spring down.Use it all the time and never have an issue.
Plus you can usually just pull the spring off the the cup as the ca does form an overly strong bond. Its enough to keep the spring, but not enough that you cant get it off.
WIDELOAD is offline   Reply With Quote
Old 02-25-2011, 06:57 AM   #20
Talking
Thanks, , loads of good ideas here!
Tags
springs
