03-27-2011, 06:53 PM | #1 |
Newbie Join Date: Feb 2010 Location: clinton twp/mt clemens
| torque stall?
Ok so I went to my hobby shop and they have a crawler course in the back. I put my truck on the crawler course and it would go ok but if the wheel went into a deep hole or was wedged against something, the truck would just try to move but it would quit, so I would have to pick it up and set it back on a flatter area. After doing this I could smell something burning from the motor and it was extremly hot to the touch. I took the motor out and replaced it with a spare 55T motor and it still did the same thing. What's wrong? Is it my esc?
03-27-2011, 06:58 PM | #2 |
I wanna be Dave Join Date: Oct 2008 Location: I miss Rowdy
First, what crawler do you have. Since it sounds like its a shafty. Likely causes of stalling a motor out is insufficient battery amperage, geared too high, or just plain crappy motors. All of these things will stall a truck out when bound up in a hole. Post up some specs of your rig and it will be easier to tell what is going on. |
03-27-2011, 07:02 PM | #3 |
Quarry Creeper Join Date: Aug 2009 Location: another state of mind..?
i have the same problem i think it is that the tire/s are geting weged tobether and so they cant spin if you keep trying to go the motor starts to smoke and if you still keep on it the motor will fry try hitting it at an angle and it will be ok if it still does it somthing is probibly wrong. my ax-10 kit is running 14tooth pin and a 45 or 55t Last edited by 86zuk; 03-28-2011 at 08:34 AM. Reason: adding some |
03-27-2011, 07:41 PM | #4 | |
03-27-2011, 10:49 PM | #5 |
Quarry Creeper Join Date: Dec 2005 Location: Tacoma
the stock 27 turn and the pinion that the RTR has is set up more for bashing and not rock crawling... you need to swap out to a much smaller pinion or swap to a 35turn or 45turn motor... |
03-28-2011, 06:33 AM | #6 |
Rock Crawler Join Date: Nov 2010 Location: Ohio
Yeah, most likely the pinion is the issue. I swapped in a 20 tooth on my RTC just to try it out and it would bind up way to easily. Only have bind issues with the 14 tooth when a wheel is completely wedged, and then the truck is flipping it's self.
03-28-2011, 08:30 AM | #7 |
Rock Crawler Join Date: Oct 2010 Location: Abbotsford BC
Do you have a slipper clutch? The reason for it's existance is to prevent exactly what you are describing.
03-28-2011, 09:11 AM | #8 | |
Quarry Creeper Join Date: Jun 2008 Location: Central KY
Getting a lower turn motor and changing the pinion will give you more torque and low end control to work with, but the majority of the time if you get in that kind of a situation, it will just continue to wad the tire up and either smoke the motor, twist off a drive shaft, or break an axle or cvd. Take the penalty and reposition the truck. BTW, that hot smell and burning sensation your fingers experience, happens when a heavy throttle finger cooks the windings in the motor when it gets in a bind. It has nothing to do with the esc. Last edited by Boogie; 03-28-2011 at 09:14 AM. | |
03-28-2011, 06:53 PM | #9 |
Quarry Creeper Join Date: May 2009 Location: Under Communist Occupation
A good 55T might be an option too.
