03-29-2011, 03:51 PM | #1 |
Newbie Join Date: Mar 2011 Location: south bay
| Gearing question???
Is it possible to make the rear wheels spin slower than the front? If so would this even be helpfull or is this a bad idea? It seems it would for climbing and decending hills. Im not talking about dig. I dont want either to lock just roll slower. I think on an moa you could just change the pinion gears so theyre different but on a shafty would this be possible? Is there a way to program an esc to do that? Thanks |
03-29-2011, 04:18 PM | #2 |
Pebble Pounder Join Date: Jan 2010 Location: Joliet
Yea its possible. And it helps climb better. I have overdrive gears in the front and underdrive in the rear axle. I like it a lot. What rig are you trying to do this on?
03-29-2011, 04:25 PM | #3 | |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
They've had over drive & under drive gear available for a long time. | |
03-29-2011, 04:41 PM | #4 |
I want to do it on a losi comp crawler. Does it matter that they have worm gears?
03-29-2011, 05:09 PM | #5 |
How do I do this? and is it possible on a losi?
03-29-2011, 06:09 PM | #6 |
on the losi cc the way to do it is run the new hd gears in the front since they have a 21:1 ratio over the stock 25:1 ratio. search in the losi section and you will find a thread on it.
03-29-2011, 08:51 PM | #7 |
Sweet. Is it worth doing? I mean does it make a big difference? I imagine it wears the rear tires out quicker than the fronts.
03-30-2011, 03:13 AM | #8 |
Other way around. You tend to wear out fronts quicker and they are rotating faster than the rears. |
03-30-2011, 05:43 PM | #9 |
03-30-2011, 06:55 PM | #10 |
You front wear because they are turning faster, it doesnt actually 'drag' the rear. It is worth doing, better on climbs, smaller turning circle and i found that side hills are better as well (with an axial, Losi is a different kettle of fish) Down hill there wont be much change. Best way to find out is suck it & see. |
03-31-2011, 01:37 AM | #11 |
Makes sence. Im gunna try it on my losi so well see how it goes. |
03-31-2011, 08:26 AM | #12 |
Rock Stacker Join Date: Feb 2010 Location: buffalo
I was just going to start a new thread with this question and it looks like it is already hear. Is it better to go 1 up in front and 1 down in the rear ?or 2 up in front and leave the rear stock? would that be the same? |
03-31-2011, 09:24 AM | #13 |
03-31-2011, 11:14 AM | #14 |
not one specific rig just wondering if that is a sound theory.
03-31-2011, 11:27 AM | #15 | ||
A lower gearing will help reduce torque twist so that is many times a good idea on a shafty. On an MOA an lower gear ratio can help reduce start up stall and such. There are many different factors. | ||
03-31-2011, 04:21 PM | #16 |
i get your point, lets say one tooth up or down not a available gear ratio. or a stock ax-10 and talk available gears |
