Thread: Transfer case/ axial axle
Old 04-11-2011, 06:00 PM   #1
Default Transfer case/ axial axle
So I've searched bur no results other than people showing their transfer case in rigs, but I was wondering about the rear axle? I know when people use trans they got to flip the rear so that both axles go in the same direction but with the axial axle, how do you mount the r2j 4-link? Do you guys just redrill holes on the bottom of the case or what?
Edit: show pics if you can please, makes it easier for me to understand
demonoid369 is offline   Reply With Quote
Old 04-11-2011, 06:08 PM   #2
PapaGriz Yo
Grizzly4x4's Avatar
You don't need to flip the rear axle when running a transfer case.
It would be a poorly designed transfer case that would spin the front output one direction and the rear output the opposite direction.
Grizzly4x4 is offline   Reply With Quote
Old 04-11-2011, 06:16 PM   #3
Didn't see the bigger picture of that I was thinking in my head about the direction that the front drive shaft was going and then turning that with the rear and it would go the opposite(sounds stupid and confusing now that I'm typing it out) then what was that I remember seeing something about having to flip your axle?
Old 04-11-2011, 06:34 PM   #4
you might be thinking about 6x6s where the 2nd axle has a third member on the front and rear and you have to flip the rear or some transfer cases have both shafts coming out both sides of the case if you run both axles off the same shaft it will work like normal but if you run one axle off one shaft and the other axle off the other shaft it acts as a counter transfercase witch is supposed to help with torque twist and then one axle will have to be flipped hope this helps
muddawg is offline   Reply With Quote
Old 04-11-2011, 06:41 PM   #5
Oh ya!!! I remember now lol thank you muddawg, ya sorting through things I remember, can't always remember I saw it
Old 04-11-2011, 06:48 PM   #6
i know the feeling
