04-14-2011, 12:57 PM | #1 |
RCC Addict Join Date: Feb 2006 Location: ccxc
| Shock cap mod
I searched but wheres the write up on how to do the big bore cap mod?
04-14-2011, 01:08 PM | #2 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
Here ya go
04-14-2011, 01:54 PM | #3 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
04-14-2011, 01:56 PM | #4 |
04-14-2011, 01:59 PM | #5 |
LOL, i was intrigued, but mostly confused...... |
04-14-2011, 02:01 PM | #6 |
04-14-2011, 03:15 PM | #7 |
Quarry Creeper Join Date: Nov 2008 Location: Natick
Try this link Rod end shock caps-done the right way! |
04-14-2011, 03:31 PM | #8 | |
And it's doesn;t show you how to do the mod to a stock shock cap. | |
04-14-2011, 07:45 PM | #9 |
04-15-2011, 01:46 AM | #10 |
Updated with pics Y'all These were for the wifes XR10 BJv4 Thanks DEEZUL for making the title search friendly. Now everyone who searches will find this thread Last edited by Rig Rocker; 04-15-2011 at 09:42 AM. |
04-15-2011, 12:38 PM | #11 |
Thanks for the writeup
04-15-2011, 02:26 PM | #12 |
RCC Addict Join Date: Aug 2007 Location: Seattle
Nabil has a short write up about drilling the eye hole out enough to slide a revo ball in and use a couple shock o-rings and washers to keep it centered. Not sure where but it's really easy and costs little.
04-15-2011, 04:47 PM | #13 |
04-16-2011, 05:46 PM | #14 |
Did it tonight. Tapping was a pain and one came out too big but with the silicone nut and bolt I figure it should be good.
04-17-2011, 07:47 PM | #15 |
Rock Stacker Join Date: Sep 2009 Location: antioch
great info thanks for the step by step cant wait to do it.
06-03-2011, 07:58 PM | #16 |
Pebble Pounder Join Date: Aug 2008 Location: San Diego
What screw is everybody using to do this mod, I can't find a m4 x 15 pan head screw anywhere. Is there a different screw that can be used instead of a pan head since a lot of places don't even know what a pan head screw is.
06-04-2011, 01:21 AM | #17 |
RCC Addict Join Date: Nov 2010 Location: England
button head? i got some with flanged (built in washer) head like this http://cgi.ebay.co.uk/M4-x-16-Stainl...item25640713e0 |
06-04-2011, 05:10 AM | #18 |
Quarry Creeper Join Date: Apr 2010 Location: Southern Aroostook County
If the extra length of adding the ball end is what youre after then this is great but if you dont want to make your shock longer then..... 1. with a Dremel and a milling bit enlarge the hole in the shock cap to fit what ever ball you want to use ,but you want the ball to fit tight or not quite fit in the hole. 2. use a small ball milling bit and your dremel to carve a channel in the center of the cap hole. go slow and do several passes until you have a indent all the way around the inside of the cap hole making sure the channel is centered. 3. enlarge the hole until you can get the ball insert into the hole. you want the outside of the hole ( on both sides) to be slightly smaller than the channel you just put in the hole so you can get a "snap" fit just like a shock cap that was designed to use a ball. I just did this mod to a set of Traxxas big bores ,it took a little time but it seems to work great! I know this would be more easily understood with pics but the lake ate my camera yesterday......... |
06-04-2011, 09:19 AM | #19 |
Thanks guys that was exactly what i needed.
06-23-2011, 09:17 AM | #20 |
Rock Crawler Join Date: May 2011 Location: SoCal
This seems like a good thread to ask this. I'm wondering how the shock cap mod affects the shock length. I've been told the shock options are: #2660 3.5" #2661 3.75" #2662 4" Are those the true eye-to-eye max lengths of those shocks? (Edit -- Traxxas told me that those dimensions are in fact center to center, not overall length. I haven't verified that yet.) Then fitting the flush-grind / locknut / traxxas rod end, how much do you increase those lengths? Last edited by WAM; 07-07-2011 at 11:28 PM. |
