04-30-2011, 12:29 PM | #1 |
Rock Stacker Join Date: May 2010 Location: N the hills Arkansas
| Need info on how to install rear steer on my LNR
My rig is a Losi Night Crawler. Like the title states I need a how to with parts I will need and instructions. I know I will need a new controller, but which one? thanks for any help! Last edited by blacktoothgrin; 05-03-2011 at 01:00 PM. |
04-30-2011, 08:17 PM | #2 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
What type of crawler are you planning on running? That would help. You'll need at least a Futaba 4PL radio, they've got really nice steering functions. My girl runs one on her dual steering Bully MOA. so, list should include, 4ch. radio/rx, 2 servo's (around 330oz preferably) "2" BEC's (one for each servo & direct wired). You could also use a Punk RC steering computer with a 3 channel radio. (I have one but did not use it since I got a 4ch radio for my girls rig.) If you're not running a separate dig unit you can use a 3ch radio= ESC, and both servos or the Punk computer. |
05-03-2011, 12:58 PM | #3 |
I accidently put LNR, but its a LNC "Losi Night Crawler" The list you gave me does help a lot tho I'm not into comping it, just want to go cheap to achieve rear steer. I already installed a heavy duty front steering servo. Since you know excatly what my crawler is, does the list change or stay the same? Like I said I'm on a limited budget. Thanks Last edited by blacktoothgrin; 05-03-2011 at 01:03 PM. |
05-03-2011, 02:40 PM | #4 |
Quarry Creeper Join Date: Aug 2004 Location: Southwestern PA
You will need to get the steering parts from Losi to convert the rear axle to steering. You will need the C-hubs, knuckles, CVD axles, servo mounting plate and steering linkages, as well as the bearings and screws/hardware to go along with all those parts. This is in addition to the radio, servo and BEC. I would just use one BEC powering up the receiver unless the servos you choose are monster amp hogs...
05-03-2011, 02:53 PM | #5 |
Here's a parts list of Losi parts you will need: losa 1030 spindle and carrier set, $9.99 losa 1517 kingpins and hardware $7.99 losa 3196 front CV driveshaft set $37.99 losa 4037 Servo mount and hardware $11.99 losb 2036 steering track rod and bushings $8.99 losa 6940 6x12mm bearings(4) $9.99 Plus some screws, nuts etc. Keep in mind these are stock LNC parts. You can upgrade to LCC pieces in a few cases for s few bucks more... |
05-03-2011, 02:56 PM | #6 |
Rock Stacker Join Date: Apr 2007 Location: Seattle
The Futaba 3PMX is a great radio for 4WS. Used it for awhile on my MRC.
05-03-2011, 05:41 PM | #7 | |
(Just bustin.......wish I could always post as fast!!!!!) Thanks for the info. | |
05-03-2011, 06:13 PM | #8 |
Lotta help here! Thanks everyone, escpecially you Digger That parts list is awsome and knowing what radio to get does for me too. Now I just need to see pics of the install |
