Tamiya Gear Head Gear reduction ??? I put this here becasue it seems like it could work pretty good for any crawler... Heres the specs: http://www2.gpmd.com/image/t/tamx7302.jpg This is the Gear Head Motor 380K75 & Pin Spike Tire Set from the Tamiya Robomaterial Series. Suitable for Ages 12 & Older. FEATURES: Designed for use in building competition-ready robots. Powerful, compact Type 380 gear head motors. The high torque motors, with gear of 75:1, can be used with a DC7.2V power source. Mounted 1:10 scale monster pin spike tires that are ideal for traversing rough terrain. Position selectable metal motor mounts. Illustrated assembly guide on package. INCLUDES: (2) Motors (2) Wheel Hub Shafts (2) Tires Hardware (2) Motor Mounts Box Wrench & Allen Wrench REQUIRES: Assembly SPECS: Tire Width: 60mm Tire Diameter: 130mm Max Load: 2kg per wheel Motor Specs - Voltage: 7.2V RPM: 242r/min (@ no load) Current Consumption: 0.67A (@ no load) Weight: 180g Gross Weight: 660g (with tires) Running Speed: 1m per 0.74 sec. COMMENTS: Do not use voltage over 7.2V. 380 size motor and a gear reduction... seems like we should be able to get longer run times and less weight. Just a thought. |
All i See is a little red X, |
yeah no pic it isnt workin |
1 Attachment(s) Right click on red "x" and you can get to it or.... Let an old timer show you how it's done :flipoff: |
TTT..... Back from the dead. Has anyone tried these yet? |
