Thread: Tamiya Gear Head Gear reduction ???
Old 04-26-2006, 12:03 PM   #1
Powered by Awesome
TwistedXT's Avatar
Default Tamiya Gear Head Gear reduction ???
I put this here becasue it seems like it could work pretty good for any crawler...
Heres the specs:
This is the Gear Head Motor 380K75 & Pin Spike Tire Set
from the Tamiya Robomaterial Series.
Suitable for Ages 12 & Older.
FEATURES: Designed for use in building competition-ready robots.
Powerful, compact Type 380 gear head motors.
The high torque motors, with gear of 75:1, can be used with
a DC7.2V power source.
Mounted 1:10 scale monster pin spike tires that are ideal
for traversing rough terrain.
Position selectable metal motor mounts.
Illustrated assembly guide on package.
INCLUDES: (2) Motors (2) Wheel Hub Shafts
(2) Tires Hardware
(2) Motor Mounts Box Wrench & Allen Wrench
REQUIRES: Assembly
SPECS: Tire Width: 60mm
Tire Diameter: 130mm
Max Load: 2kg per wheel
Motor Specs -
Voltage: 7.2V
RPM: 242r/min (@ no load)
Current Consumption: 0.67A (@ no load)
Weight: 180g
Gross Weight: 660g (with tires)
Running Speed: 1m per 0.74 sec.
COMMENTS: Do not use voltage over 7.2V.
380 size motor and a gear reduction... seems like we should be able to get longer run times and less weight. Just a thought.
TwistedXT is offline   Reply With Quote
Old 04-26-2006, 07:04 PM   #2
All i See is a little red X,
Magic is offline   Reply With Quote
Old 04-26-2006, 09:03 PM   #3
yeah no pic it isnt workin
truegaintfree is offline   Reply With Quote
Old 04-26-2006, 11:13 PM   #4
Right click on red "x" and you can get to it or....
Let an old timer show you how it's done
toyofast is offline   Reply With Quote
Old 08-06-2007, 12:33 AM   #5
TTT.....
Back from the dead. Has anyone tried these yet?
