05-19-2011, 06:48 PM | #1 |
Newbie Join Date: Mar 2011 Location: Flint
| Barrel Nuts?
Does any one know of a company that makes 6mm barrel nuts? |
05-19-2011, 07:08 PM | #2 |
Quarry Creeper Join Date: Dec 2009 Location: At your moms,she says hi!
Try mcmatercarr.com Or this i dont know if this is what your looking for or not http://www.anzor.co.nz/?t=173 Last edited by fastfred28; 05-19-2011 at 07:15 PM. |
05-19-2011, 07:28 PM | #3 |
Did you check RC4WD?
05-19-2011, 10:56 PM | #4 |
I didn't see any on RC4WD. But those others might do it. Thanks.
05-21-2011, 12:00 AM | #5 |
Cheap way may be to cut some aluminum or steel tubing to length, tap it and locktite a bolt in one end. Basically, make your own barrel nut. The size tubing depends on the diameter of the shaft it has to screw onto. |
05-21-2011, 12:05 AM | #6 | |
Quarry Creeper Join Date: May 2004 Location: SW of Chicago
Also how long? | |
05-21-2011, 06:19 PM | #7 |
Inside threads. And I am not sure on the length. I am interested in getting some hub extensions and really the only hold up is the barrel nuts. If I were to guess on the length I would have to say 1/2 to 3/4 of an inch. And I would be interested in making my own but would they be strong enough on a larger crawler? |
05-22-2011, 12:36 PM | #8 |
I made some out of a socket head screw. I just drilled the inner diameter, tapped and cut to length. I would be willing to do this as a service if interested. Here is a picture on the front axle. I am running wideners on the front end. |
05-22-2011, 12:45 PM | #9 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
Say Erik D , what is that tierod end from that has a drag link boss molded in it?
05-22-2011, 01:08 PM | #10 |
05-22-2011, 06:14 PM | #11 |
I could drill and tap a bolt if need be. To use a bolt wouldn't I have to remove the outer threads for a good fit?
05-22-2011, 09:52 PM | #12 | |
You will also need to drill/tap pretty close to center so it does not offset your wheel. A lathe is ideal. | |
05-22-2011, 09:56 PM | #13 |
I may give that a try. Thanks for the info.
