12-02-2004, 11:43 AM | #1 |
Pebble Pounder Join Date: Nov 2004 Location: Thomaston, CT
| soldering???
I see that most are using brazing to put together a tube chassis. With it being the winter season and not many outdoors projects left I have considered building a tube chassis. Getting a torch and faux sounds a little pricier than I want, will soldering work or no?
12-02-2004, 12:57 PM | #2 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
| Re: soldering???
The only solder I'd even consider using is Silver Solder, and it's about $1.50/ft. If I'm right, that's about $10.75 for half an ounce. Safty-Silv is 12.75 per ounce, Flux is $6 for a small tub. |
12-02-2004, 01:05 PM | #3 |
Quarry Creeper Join Date: May 2004 Location: Hartford, Connecticut
| Re: soldering???
Rockhound, you're still going to need to get a MAPP gas torch, silver solder, and paste flux if you want to solder up a tube frame. I got the torch, solder, and flux at Sears for $50. The torch-silver soldering process isn't vastly different from brazing. A soldering iron and standard solder might not produce joints that are strong enough for a tube frame crawler. Take a good look around on RokToy's website for all of the info that you will need to make a tube frame. RokToy's website: (http://www.mindspring.com/~jayk6/rcs...ab/tubefab.htm) |
12-02-2004, 03:06 PM | #4 |
| Re: soldering???
Thanks for the tips and the website. Now that we bought a house and are about to get married I dont have the cash to keep doing real full size offroad toys - so I have to go with the small ones (although they can cost just as much since I had a chopped up Cherokee that wheeled like no other for a total of $300). I am bored of not having stuff to tinker with and fix, and making a tube chassis should be just the project to get me in the shop and away from the woman . Just so I have an idea how this works - when does the flux go on, before the brazing rod or after? |
12-02-2004, 03:08 PM | #5 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
| Re: soldering???
Hound I just want to congradulate you on spelling soldering correctly. I can't tell you how many times I've seen it spelled sodder. Freakin moron's
12-02-2004, 03:18 PM | #6 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
| Re: soldering???
I sodder everything on my TXT. I even soddered the tires on!
12-02-2004, 03:39 PM | #7 |
| Re: soldering???
I am a high school math teacher - even in math I need to spell correctly or else the students rip you a new one .
12-02-2004, 03:49 PM | #8 | |
Dirt Addict Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
| Re: soldering??? Quote:
Flux goes on before you heat to braze. Jay | |
12-02-2004, 03:59 PM | #9 |
| Re: soldering???
Thank you. Dont need to run already - just practicing - actually it is advice from HER grandfather . |
12-02-2004, 08:35 PM | #10 |
Quarry Creeper Join Date: Nov 2004 Location: Mid TN
| Re: soldering???
You should always listen to your fiance's grandfather. My wife's grandfather told me what women in his family always try to run things, and you have to put your foot down hard, early, and often. He did append this statement muttering under his breath something to the effect of "it's the only way to keep the damn things out of your mouth..." |
12-03-2004, 05:18 AM | #11 |
| Re: soldering???
Rockhound, always remember these words that you said yourself: "I am bored of not having stuff to tinker with and fix, and making a tube chassis should be just the project to get me in the shop and away from the woman." This is the secret to a happy marraige! Even if it does mean a marraige between yourself and the shop... |
12-03-2004, 06:41 AM | #12 |
| Re: soldering???
Funny you mention the muttering and trying to keep your feet out of your mouth - that is basically how I was informed .
12-10-2004, 04:48 PM | #13 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
| Re: soldering???
if you are going to use a torch to braze does anyone think it would just be easier to melt the pieces together and add add a little filler metal. ive found that this works good with just a little practice and seems a lot cheaper than brazing the only thing you would have to change is MAPP to oxy/acc |
