07-05-2011, 08:08 PM | #1 |
Rock Crawler Join Date: May 2011 Location: SoCal
| Testing wall
I carpeted a 4' shelf board and fitted it with a digital protractor which I used for link testing. It worked well. But carpeting seems much grippier than rock, so now I'm thinking of building something simulating rock but adjustable angle like my carpet ramp. This would actually be testing grip for evaluating foams, comparing tires and such. Was thinking of maybe a couple sheets of 4x4 ft plywood plastered with a concrete grout material or stucco. But don't know how well it will stick and whether a thin frosting will hang in without cracking and crumbling. If that doesn't work, there's sand paint, but I suspect that will be less realistic. Has anyone built any largish artificial "rock" walls? I'm thinking flat panels here with adjustable legs to allow variable angles. But that approach may be a little flexy. |
07-06-2011, 05:12 AM | #2 |
We commonly use a flat board covered with 60 grit sandpaper to test climb angles.
07-06-2011, 06:50 AM | #3 |
Rock Crawler Join Date: Nov 2008 Location: Beloit,ohio
Weve used burlap over diff. items covered in resin. Works great & pretty durable.
07-06-2011, 09:13 AM | #4 | ||
I'll test the sandpaper approach. I'll just take several grades of paper out to the rocks, find a rock slope that maxes out my rig and tape various papers on that same section to see if it's better or worse than the rock. Thanks guys. | ||
07-06-2011, 10:06 AM | #5 |
The sandpaper board is so people can compare from one place to another as well as doing before/after tests @ home (inside where it's warm & dry!). The Venom Creeper forum has a thread just for testing & what people can do. Sorta like comparing dyno charts on cars. |
07-06-2011, 01:38 PM | #6 |
| Link, if you have it? Searching their forum for "testing" just gave me a short thread on testing their stock tires. I assume you're referring to something bigger.
07-06-2011, 02:09 PM | #7 | |
07-06-2011, 02:53 PM | #8 |
Fun read, thanks.
07-06-2011, 09:02 PM | #9 |
Quarry Creeper Join Date: Dec 2010 Location: Earth
07-06-2011, 09:08 PM | #10 |
07-06-2011, 10:34 PM | #11 |
07-07-2011, 12:20 PM | #12 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
1/2" cement board screwed to a frame. Then coat w thinset mixed with motar sand. Very close to abrasive rock and holds up well to water/freeze damage. Fairly cheap too
07-10-2011, 06:08 PM | #13 |
Rock Stacker Join Date: Mar 2011 Location: SS
I would definitely think some sort of stucco solution would work. Or you can always try spray adhesive with sand. Or grout with small pebbles/rock from the garden center. Possibilities are endless, just depends on the type of terrain around you.
07-11-2011, 09:00 AM | #14 | |
07-11-2011, 10:57 AM | #15 |
Thanks for all the suggestions guys. What I went with was covering a sheet of osb with tar roofing paper, rocked on one side. It's grey, heavily textured and a little sandpaper-ish. But very flexible. If it has excessive grip compared to the local rock, I might be able to tone it down with a little spray paint or something.
