05-19-2006, 11:54 PM | #21 |
I wanna be Dave Join Date: Sep 2004
getbent, just finished up the rear axle on my rig.once again this is an excellent mod.i havent tried it out yet but it looks like it should hold. one change i made and was due to the fact i didnt have the correct aluminum sheet you used ,so what i did was used .020 lexan for the shims on the axle gear.seems like it should hold up. |
05-21-2006, 08:43 PM | #22 |
Rock Crawler Join Date: Dec 2005 Location: houston
Sounds great, sometimes you just gotta use what you can get your hands on. I already had the aluminum, but the lexan should work great too. Keep us informed on how things hold up when you get achance to bash it some. Mine is still holding up great, not one sound from the gears. |
05-21-2006, 10:15 PM | #23 |
will do. i hope ot get out in the next day or so.
05-23-2006, 11:15 PM | #24 |
getbent,i have some good news and bad news...no clicking ! but i did have a problem. the metal claw that grabs the planetary came undone and wore a groove in the plastic. i had a feeling this would happen as when i was bending the tabs i bent them to far and had to rebend them to the correct spot.it was my own fault. ill post pics of it in a bit. **EDIT** heres a pic of the planetary and hub.notice the groove worn in the plastic cover of the planetary. Last edited by twisted; 05-24-2006 at 11:16 PM. Reason: more text |
05-30-2006, 10:10 PM | #25 |
hey getbent how are your axles holding up with this new mod ? the same thing happend again today as shown above. but the new mod has helped alot but created another weak link. im trying to think of a way to solve this problem.
05-30-2006, 11:41 PM | #26 |
Newbie Join Date: May 2006 Location: Scappoose
Glue the metal piece and the planetary together, tis what I did and it works like a charm. I have to do this axle fix though cus I'm gettin the death click like no other |
05-31-2006, 04:28 PM | #27 | |
they were glued.the problem is that this mod works so well the strain has ot go to the next weakest link. | |
06-03-2006, 04:27 PM | #28 | |
Quarry Creeper Join Date: Apr 2006 Location: Gervais
06-04-2006, 07:18 PM | #29 |
Pebble Pounder Join Date: Nov 2005 Location: NHFF World HQ, TN
I drilled through the white plastic coupler through the axles and put 3mm pins in them. After that, along with the other axle mods, the axle case busted and let the main drive gear slip... oh well
06-05-2006, 11:53 AM | #30 | |
im not quiet grassping what did, any pics? | |
06-30-2006, 08:44 PM | #31 |
Newbie Join Date: May 2006 Location: lake county
would copper tubing work???
07-01-2006, 01:16 PM | #32 |
i dont see why not.copper is kind of soft so becarful.
07-01-2006, 02:46 PM | #33 |
ok thanks
07-08-2006, 11:25 AM | #34 |
Rock Stacker Join Date: Dec 2005 Location: Lowry City, MO
| bump, this needs to be a sticky
09-19-2006, 01:46 PM | #35 |
Pebble Pounder Join Date: Jun 2006 Location: Rapid City
| Wheel Sleeves I stocked up on all the materials need to do this great mod and found that the 7/16 brass tubing is too big to sleeve my wheels. I also found it hard to find an aluminum sheet that is .025 thick to shim the axle so I'm on a quest for an alternative. I'm thinking of using a large washer that will fit up against the gear. I'll try and post what I come up with when I'm done. I can't believe that they manufactured these with so much slack in the gearboxes! |
09-19-2006, 02:14 PM | #36 |
Pebble Pounder Join Date: Jul 2006 Location: USA
I used some washers I had in my junk box... worked like a charm, only thing I had to do it drill them out a little larger.
09-19-2006, 07:26 PM | #37 | |
09-19-2006, 09:46 PM | #38 | |
09-21-2006, 01:58 PM | #39 |
The size of tube that I used on my wheel hubs was 13/32. I also just found a washer that fit the white gear on the axle and it worked great. Everything else was just as you stated. No more slack and the gear box works like it should have to start with. I can't wait to hammer down on the throttle with this thing now. |
10-06-2006, 03:30 PM | #40 | |
Newbie Join Date: Aug 2006 Location: San Diego and Tijuana
