08-06-2011, 09:59 AM | #1 |
Pebble Pounder Join Date: Apr 2011 Location: scranton
| long travel shocks
Hello, i'm looking for some suggestions on some shocks with a good amount of travel so i can start looking in the right directions. |
08-06-2011, 09:01 PM | #2 |
I get my shocks from rc4wd.com they have crawler shocks up to 120mm (all metal)
08-06-2011, 10:51 PM | #3 |
Rock Stacker Join Date: Jul 2011 Location: Elk River, MN
08-06-2011, 11:43 PM | #4 |
...they're high speed, baja shocks...not really designed for crawling, but hey, go for it Last edited by crawl-o-matic; 08-06-2011 at 11:47 PM. |
08-08-2011, 10:46 AM | #5 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
what travel are your current shocks? That way we can help you a little better with something of quality and longer than you have.
08-08-2011, 12:01 PM | #6 |
HPI Savage shocks were always the standard for long shocks. You should probably give some more info, why do you want long travel shocks? |
08-08-2011, 12:14 PM | #7 |
RCC Addict Join Date: Dec 2007 Location: Moncton, NB, Canada
08-08-2011, 01:30 PM | #8 |
| I can't for the life of me figure out why some one would want that much, sure it looks cool but does not ever seem to function as well as one would think. I personally have limiters to keep from over articulating on stock LCC shocks.
08-08-2011, 01:59 PM | #9 |
| That is what he is refering to, 180 degrees is a joke that has been around here for years and years.
08-08-2011, 03:44 PM | #10 |
i currently have stock rock force shocks(no idea on the length or travel) and im not pleased with them at all and i have a wreckluse chassis on the way that im putting my rock force axles in and figure ill need some bigger/better shocks as the wreckluse looks like it sits high up basically looking for all metal body (preferred) and a descent length as i don't prefer the droop set up for what i do.
08-08-2011, 03:47 PM | #11 |
You DON'T need long travel shocks for the Wreckluse. A standard 4" shock will work.
08-08-2011, 04:02 PM | #12 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
I'd think some SCX-10 shocks with a cap mod would work really well for that chassis.
08-08-2011, 04:21 PM | #13 |
ok then im open to suggestions on good 4 inch shocks thanks again
08-08-2011, 04:39 PM | #14 |
08-08-2011, 08:26 PM | #15 |
I say again: rc4wd |
08-08-2011, 08:51 PM | #16 |
08-08-2011, 09:16 PM | #17 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
I like the Traxxas shocks as well. Traxxas 2660 is 3.5" long Traxxas 2661 is 3.75" long Traxxas Big Bore XL is 4" long they all use the same hardware, and are pre-assembled before you get them. Just add oil and springs (Except for the big bore XL which has springs) These shocks are stupid easy to cap mod, and work awesome with no leakage. Traxxas all the way. Casey |
11-03-2011, 12:04 PM | #18 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
Bought some Traxxas big bore shock (for E-Maxx, p/n: 4962 i think), the spring (red) that come with it is way too stiff. Any alternative spring? The shock is 19mm (3/4") in diameter, not many spring i can found will fit.. |
11-03-2011, 05:10 PM | #19 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
Losi springs for their 4" shocks will fit. Or you can get lower cups to fit mini-t springs, check the vendors section for the details on them. |
11-04-2011, 12:24 AM | #20 |
like this one? LOSA5147 2.75" Spring 1.8 Rate, White | eBay I have checked out the vender section and found the Jeepindoug's lower cup for mini-T spring. But it would be easier if I can just get a softer spring to fit. |
