Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: tamiya mini
Old 02-02-2004, 10:40 PM   #1
Default tamiya mini
has anyone heard of or seen in action a tamiya trail master it's supposed to be a mini of the txt?
dheavychevy is offline   Reply With Quote
Old 02-02-2004, 11:00 PM   #2
Default Re: tamiya mini
my bad it's only a 2wd but how about building something off of the wild willys or something in that ball park or is the tlt the way to go?
Old 02-03-2004, 06:24 AM   #3
binaryterror's Avatar
Actually the Tamiya Trail Master is a toy, meant to entertain young Rc'ers.
The new Tamiya TLT-1 is a mini TXT-1. 4 wheel drive, uses a 540 motor, cantilever set up, and the option of 4 wheel steering.
binaryterror is offline   Reply With Quote
Old 02-03-2004, 05:56 PM   #4
sweet now to decide on a tlt or a txt or both
Old 02-03-2004, 05:57 PM   #5
Old 02-04-2004, 11:10 AM   #6
I just buit a TLT-1 kit for the hobby shop.... It goes together real well, and has a lot of potential as a mini crawler.. If you're into the mini stuff,, you should definitly take a look at it.. Some of the guys at the shop are crawling the Kyosho mini-Z's... they're only 2 wd, but,, they have some after market parts available,,, ( wheels, tires, shocks, etc. ) to make them better at crawling ... Go give the TLT-1 a look at your favorite hobby shop ...
CHSRacing is offline   Reply With Quote
Old 02-04-2004, 07:13 PM   #7
Yeah I'd like to buy a TLT-1 too. I think it would be cool to crawl with and would look awsome! If you get one post some pics please!
jugg_crawler
jugg_crawler is offline   Reply With Quote
Old 02-05-2004, 10:29 AM   #8
the tlt-1 is a great little truck, emphasis on the word little, tho. don't expect to be conquering some huge rocks or anything, but it will go over most anyhting smaller than a soda can, and i've had it climbing the huge snow piles outside my lhs.
the stock ground clearance is not that high, but you can use any wheel with the tamiya hex drive, i replaced the stockers with stadium blitzer wheels, and midnight pumpkin tires.
the only real drawback is that the center ball diff (while it makes a good slipper clutch) will unload when the truck wheelies, and since i have a 19 turn single and 18 tooth pinion.. my tlt wheelies often!!
if you want to do serious crawling than the txt-1 is probably more the truck for you, but to cruise around the house and crawl thru the dog's dish, over your sneakers, or crush your buddy's micro rs4, than the tlt-1 is the truck to get.
my pics:
i ditched the stock body for a nikko hummer from toys r us. the back already flipped up, and i had to dremel out the trunk anyway, so it makes for an easy way to change the batteries.
electronics: trinity 19t single, gm v3 sped control, airtronics switch reciever, associated servo (from my t4)
bdr
bigdogrod is offline   Reply With Quote
Old 02-06-2004, 05:34 PM   #9
XFACTOR's Avatar
BDR...how big are those tyres in diameiter?? like would they be bigger or smaller than maxx size tyres?
ryan oh and how big is the truck on overall length and widh..
XFACTOR is offline   Reply With Quote
Old 02-06-2004, 09:21 PM   #10
They are alot smaller than MAXX tires...the truck is 1/18th scale, not 1/10th or 1/8th!
Old 02-08-2004, 12:10 AM   #11
Sure the truck is smaller in scale and out of the box i would say that it does leave quite a bit to be desired. But with minor mods it would be better. FOr example you can replace the center ball diff with stampede parts to built a slipper clutch. The axles are more like the tamiya bruiser for you old school nuts. The second advantage is that using tamiya tractor trailer parts, you could add numerious drive axles, anyone thinking of a 6x6 or 8x8 here?
My project is going to be much different. I plan on using the stock axles, with a tamiya semi 3 speed transmission and custom t-case. The frame will also be custom, but i do plan on using the stock shocks. Here is a mock up of the truck with the axles and tires.
But i am a scale freak as you can see by this beast with diffs locking from the remote and a ton of other toys.
Nate
sig_p232 is offline   Reply With Quote
Old 02-14-2004, 08:47 PM   #12
wow the f 350 is sweet, i think im going to get a tlt 1
jmirsberger is offline   Reply With Quote
Old 05-24-2004, 03:26 PM   #13
is that f350 a tlt???????
jordanator62 is offline   Reply With Quote
Old 05-24-2004, 10:54 PM   #14
No, the ford is not a tlt, but the chevy is. Here is a little update
custom chassis in the early stages
Some custom paint, this little guys is looking good and almost ready to bash!
wood bed and a few other details
scale exhaust and a wood bed.
Nate
Old 05-24-2004, 11:09 PM   #15
Sig, your truck was in rccaraction wasn't it? If not there is a truck just like it, with remote locking axles.
MaxxZilla is offline   Reply With Quote
Old 05-25-2004, 12:16 AM   #16
Yep, that was my truck.
Nate
Old 05-26-2004, 05:56 PM   #17
can anybody show me the articul;ation of the TLT...i want a crawler but i was thinking of a small scale easy to build right out the box crawler since im not that RC inclined...ANytways how much does it cost...
pinkfloydman is offline   Reply With Quote
Old 06-21-2004, 04:07 PM   #18
did you get the body from a plastic model of the shealf
rocpede is offline   Reply With Quote
Old 06-21-2004, 11:22 PM   #19
Which body are you refering to?
Nate
Old 06-22-2004, 04:52 PM   #20
the one that is white, i think it's a ford or chevy
