can you weld on the rc4wd black widow axle? as the title says, can you weld a rc4wd black widow straight axle? |
If the aluminum is 6061 or similar then yes. However, aluminum is tricky to weld and you have to have the right equipment and setup. |
You can weld any metal with the right process and equipment. But something like that I would think the heat shrink would warp it to an unusable state. Unless maybe you could find a way to build a jig to hold it till it cools. I have never seen one in person. But could you slide a solid steel rod all the way though it? Dave |
yes. ive weleded on my RC4WD axles before, no big deal "thumbsup" the DmG |
"thumbsup"thanks |
RC4WD Wheely King axle welded on the panard bar mount & lower link mount tabs http://i103.photobucket.com/albums/m...blaster010.jpg |
cool"thumbsup" |
