10-20-2011, 09:45 PM | #1 |
Quarry Creeper Join Date: Sep 2011 Location: ???
| Need Screw Removal advice.
I had a screw strip out on one of my MRC Aluminum Chubs, My bro jacked it up with a drimmel and cut the head off the screw, now i cant get vise grips on it to turn it. This is a small screw thats going threw aluminum into plastic any way to remove it? Not to worried about the aluminum chub but would like to save the axle if I can.
10-21-2011, 05:50 AM | #2 | |
RCC Addict Join Date: Mar 2010 Location: Yelm
Those housings are dirt cheap I am certain they dont make an easyout set that small. Punch your Bro in the face and make him buy you a new housing | |
10-21-2011, 07:21 AM | #3 |
Quarry Creeper Join Date: Mar 2004 Location: Central NY
You should be able to drill out the screw, then what's left can be broken / cleaned out. Or cut the C-hub where it meets the screw an use pliers to get it out of the axle.
10-21-2011, 07:52 AM | #4 |
Rock Crawler Join Date: Jul 2010 Location: youngstown , Hillbilly heaven
Tell your dumbass buddy to go to the hobby shop and buy you some new parts.problem solved
10-21-2011, 08:07 AM | #5 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
if its in plastic, drill a small hole next to the screw so you have more room to "wiggle" it out, then fill the hole (parts tree pieces are good for this) then re-drill and tap. is the screw shaft to small to use a dremmel to cut a slot in it and turn out with a flathead? you could take it out to the shop and weld something to it as a handle to turn it out too? |
10-21-2011, 08:23 AM | #6 |
Rock Crawler Join Date: Sep 2011 Location: truckee
when i got my ax10 used it had a screw with the head cut off in where the set screw is supposed to go in the driveline. a little slice with the dremel then i was able to use a small flathead and a small ballpeen to tap it out. before after |
10-21-2011, 08:55 AM | #7 |
Yea He hasnt been back over here for a day or so he knows I'm pissed. I went ahead and ordered some more axles 60 bucks :( Going to stil try to make a slot wit drimmel and use flat tip I think that might work. |
10-21-2011, 02:01 PM | #8 |
you bought fully loaded axles? you can buy just the housing for like 6 or 7 bucks.
10-21-2011, 02:37 PM | #9 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
10-21-2011, 03:15 PM | #10 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
got any tips for a stripped screw holding a metal servo horn on?? i stripped mine so cut a slot and tried a flathead screwdriver but didnt work..
10-21-2011, 03:58 PM | #11 | |
RCC Addict Join Date: Jul 2009 Location: Dover, NH
Probably cut the head of the screw off. Then remove the servo horn. Then you "should have enough of the screw sticking out of the servo to get a grip on it with some pliers/vicegrips, etc. The only bad is the screws that many servos use to hold the servo horn on are funky threads and kinda hard to find locally. I know at least many Hitecs are this way. I would have a spare ready before doing this method as the servo horn will not stay on obviously after cutting off the head. | |
10-21-2011, 05:38 PM | #12 |
thanks rooke. im running a 645mg for a servo and hoping to hit the hobby shop next week for some grub screws so i will look then. |
10-22-2011, 11:02 PM | #13 |
Rock Crawler Join Date: Feb 2010 Location: in a Fishbowl watching time go by
you need a 2.5 mm screw can't remember the lenght tho...
10-23-2011, 08:25 PM | #14 |
Rock Crawler Join Date: Nov 2009 Location: Etowah
left handed drill bits work great for stripped/broken screws turn slow and push hard |
10-26-2011, 11:51 AM | #15 |
Newbie Join Date: Aug 2011 Location: East Helena
10-26-2011, 01:29 PM | #16 |
Rock Crawler Join Date: Jun 2009 Location: summertown
Craftsman sell a Screw/bolt extractor set good for VERY small size grubs and bolts. I use them on the grubs in my Driveshafts and pinions all the time.
10-26-2011, 04:21 PM | #17 | |
Rock Stacker Join Date: Mar 2011 Location: Alberta, Canada.
