10-22-2011, 05:46 PM | #1 |
Quarry Creeper Join Date: Mar 2006 Location: Lutz
| Where to buy Delrin sheets.....
Just wanted to know where i could buy some 1/4 inch thick Delrin sheet. I need it to build a skid plate for a buggy project im building.
10-22-2011, 05:49 PM | #2 |
RCC Addict Join Date: Jun 2008 Location: Amish Buggy PA
10-22-2011, 05:53 PM | #3 |
Oliver Custom Knives Join Date: Dec 2007 Location: Bloomfield NM , not something stupid
10-22-2011, 05:54 PM | #4 |
Ok, i`ll check them out, thanks for the fast response |
10-22-2011, 06:59 PM | #5 |
RCC Addict Join Date: Dec 2007 Location: Ward, SC
Also checkout McMaster-Carr. Should ship to Tampa pretty quick since they are located in ATL. McMaster-Carr |
10-22-2011, 07:11 PM | #6 | |
Quarry Creeper Join Date: Jul 2008 Location: lansing
10-22-2011, 07:36 PM | #7 |
I used to use McMaster , but their shipping was high. I ordered 5 - .25 sticks and a sheet from Enco and the shipping was $10 AND 2 packages. |
10-22-2011, 11:02 PM | #8 |
Quarry Creeper Join Date: Feb 2011 Location: Vancouver, WA
Try your local plastics shop if you have one. I bought my 1/4" delrin from TAPP plastics.
10-24-2011, 08:54 AM | #9 |
Pebble Pounder Join Date: Oct 2011 Location: Nashua
Can't you get HDPE from cutting boards? I've seen a lot of people on here using those. If you're in a hurry, you can usually pick it up local. |
10-24-2011, 09:58 AM | #10 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
| Not sure if others have had luck, but I build almost everything in M3 hardware. HDPE is slippery across rocks, but also around screw thread, so I was always stripping out tapped holes.
10-24-2011, 10:14 AM | #11 |
Interesting. Did you try using Heli-coils (or equivalent)?
10-24-2011, 08:14 PM | #12 |
Newbie Join Date: May 2005 Location: Sicamous BC
I don't know if a helicoil would help much, I'd be leery because its still threaded into the cutting board. Just pull it out instead of the screw. I have had success in the past just building a skid out of 2"x1/8th mild steel flat stock or whatever size would fit the bill and bolting a thinner delrin or even lexan skid to it i could replace easily when it got torn up. And steel isnt that grabby to begin with |
10-25-2011, 04:11 AM | #13 |
Well the Heli-coil has a higher resistance to pulling out because it has a significantly higher cross-sectional area of thread than the bolt does. In other words, you'd have to pull out much more of the base material with a Heli-coil than you would with just a bolt.
10-25-2011, 05:59 AM | #14 |
07-21-2013, 08:58 PM | #15 |
Newbie Join Date: Aug 2012 Location: Australia
| Re: Where to buy Delrin sheets.....
does anyone know of any good australian suppliers of delrin/acetal sheet & rod? i'm based in sydney and im trying to get just under a square metre of the stuff for making bits and pieces and i've found one or two places that want to sell it to me for $300 for 2x1m sheets (ex postage)
07-21-2013, 09:23 PM | #16 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
Online Metals has a decent selection. Rod; Order Plastic Round Alloys Acetal, Acetal AF100 PTFE Fiber Filled, Acetal LF13 PTFE Powder Filled in Small Quantities at OnlineMetals.com Sheet and Plate; Order Plastic Plate, Sheet Alloys Acetal, Acetal (CoPolymer), Acetal AF100 PTFE Fiber Filled, Acetal LF13 PTFE Powder Filled in Small Quantities at OnlineMetals.com |
07-22-2013, 05:41 AM | #17 |
Pebble Pounder Join Date: Mar 2011 Location: coastal georgia
Sometimes a water jet outfit will sell you plastic. Some of those outfits cut a lot of plastic. In fact, we have gotten lots of free drops of all sorts of plastic and metals from a couple of different ones.
