05-31-2006, 02:02 PM | #1 |
Rock Crawler Join Date: Feb 2005 Location: Hardin, KY
| i think i killed my baby
i was playing around on the rocks and it took a good hard hit to the electronics (still dont have a body on it).. but it ran fine after that... then i was driveing it around on flat ground.....it just stopped dead in its tracks, no signs of battery getting low or anything like that......i played around with the wires for a second and it started working but only worked for about 5 seconds and died again..... anyone had anything like this happen before? o yah and instead of the normal buzzing comeing from the front end, its a really high pitched whistling type sound..... |
05-31-2006, 02:16 PM | #2 |
Rock Crawler Join Date: Mar 2006 Location: Dayton
I think you killed your baby...are there any signs at all of breakage? -Dalton |
05-31-2006, 02:19 PM | #3 |
nope not at all....
05-31-2006, 02:26 PM | #4 |
Rock Crawler Join Date: May 2006 Location: Burrillville, RI
first swimming ...now smashing the eletronics.... NO SOUP FOR YOU!!!
05-31-2006, 02:29 PM | #5 |
yah if i get it running again im definately going to build some sort of protection for them.....
05-31-2006, 02:45 PM | #6 |
i think my nylint is haunted or something.... bastard works fine now |
05-31-2006, 02:50 PM | #7 |
i think im gonna put a little rollbar over them for now....just a piece of flat metal, but its better than them getting bashed off the rocks.....
05-31-2006, 03:01 PM | #8 |
actually, scratch that.....im going to walmart tomorrow, so i am going to pick up one of those clear plastic fishing organizers and put the electronics in that.....just dril a few holes in the top for ventilation...then they are completely protected....
05-31-2006, 04:24 PM | #9 |
Newbie Join Date: May 2006 Location: tempe, az
same thing was happening to me...then i noticed that the wires on the battery were loose...soldered em up and all is good.
06-01-2006, 05:32 PM | #10 |
soldering iron + finger = major pain i got the box ready to stick them in, now im just taking some unused wires off the circuit board (on-off switch, shifter, and buttons in axle) |
06-01-2006, 05:43 PM | #11 |
Rock Crawler Join Date: Feb 2006 Location: jacksonville beach
you should make a body out of a clear 2 litre coke bottle juts to save the electronics for the time being.
06-01-2006, 05:50 PM | #12 |
nah i bought a little organizer from walmart that they fit in perfectly....just had to cut the dividers out of it
06-01-2006, 06:31 PM | #13 | |
about the organizer thing, does it have a lid on it, or is it just glued in place over the circuitboards? -Dalton | |
06-01-2006, 06:37 PM | #14 |
lid
06-01-2006, 07:06 PM | #15 |
guys, i suggest this box to anyone looking for a way to seal their electronics... everything fits in PERFECTLY, i mean you would think it was made for it..... |
06-01-2006, 07:16 PM | #16 |
what're the dimensions of it? do the circuitboards fit really tight or do they flop around a bit? -Dalton |
06-01-2006, 07:22 PM | #17 |
they flop around a bit if they aren't held in with something.....you could put a little piece of foam or something in there and it would be perfect, but i just put a little dab of hotglue in 2 corners of each board.... the lid is 3.75" wide and 6.5" long....the base is about an 1/8" smaller both ways.... it came from the fishing section at walmart.... |
06-01-2006, 07:27 PM | #18 |
cool, ill be needing one when i get my new circuitboards. -Dalton |
