10-30-2011, 05:58 PM | #1 |
I joined the Band! Join Date: Feb 2009 Location: https://t.me/pump_upp
| Making scaler chassis
Hey, this will be my first scaler (though been in the RC hobby for several years). I picked up a square steel tube and plan on cutting it in half (think SCX10 chassis...). My question is: Should I form the steel before I cut it in half, or vise-versa? What have you all done? It seems like bending it first would be more practical so I would only have to do it once. Also, are there any techniques for making straight cuts with jigsaws? What do you use to coat the steel when complete? |
10-30-2011, 06:32 PM | #2 |
Rock Crawler Join Date: Aug 2009 Location: I'm a michigan boy can you feel that!
Yes, you would want to form the shape as a whole then cut in half to make sure both sides are identical. also befor you cut it in half, be sure to make your holes for the chassis also to also insure that everything is even and straight. |
10-30-2011, 07:08 PM | #3 |
Quarry Creeper Join Date: May 2010 Location: Flooriduh
I searched and found this it mite help. c channel chassis |
10-30-2011, 07:12 PM | #4 |
Rock Stacker Join Date: Jun 2011 Location: Australia
You just neeed to be sure that the chassis is even after you cut it as it will crack and warp under pressure. Just my 2 cents
10-30-2011, 07:29 PM | #5 | |
I'm certainly going to have to buy a blow torch.... Last edited by tycoonman; 10-30-2011 at 07:32 PM. | |
11-01-2011, 10:21 PM | #6 |
Found I don't actually need to apply heat to bend the steel. Still a real pain in the rear, but I'm slowly getting it done. About 2/3 now and up to the tricky part (curved front). Had to stop for the day as I started hurting my back pulling this stuff. I'll be sure to start and official build thread (MRC > scaler) when the chassis is all cut out. |
11-02-2011, 01:39 AM | #7 |
RCC Addict Join Date: Jan 2007 Location: San Jose
I would form it before cutting it. Where did you get the tube? Will be following this for sure. |
11-02-2011, 07:32 AM | #8 |
