11-08-2011, 10:28 AM | #1 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
| Which MIP stub axle will fit MIP AX10 center driveline cups ??
I am fabbing an 1/8th scale solid axle from various pcs. I want this thing bullet proof to haul around a 12lb scale rig that keeps blowing the current CV joints at the stubs. Yes, I could have gone with some Twinforce axles, but quite often I am the one who 'just has to build it myself'. I am using AX10 center driveshafts as front axle shafts. I could fab my own stub axle from 6mm rod, but would rather buy it from a known part. What 6mm stub axles will fit in the driveshaft end? A) Ofna Racing CVD Axle (MIP) 6MM 39076 | eBay Discontinued. Smaller CV ball size. B)MIP 1543 CVD Axle HPI Savage 21 Front or Rear | eBay C) RC10 B4 Replacement MIP CVD Axle | eBay D) (but I think they are 5mm shafts?) Traxxas Slash 4x4 MIP X-Duty CVD Rear Axle MIP10131 | eBay Correct CV ball size, 5mm shaft, M4 thread Last edited by sweli; 11-09-2011 at 03:08 PM. |
11-08-2011, 10:57 AM | #2 |
Anyone know about the 11102 for the Summit/Tmaxx/Emaxx/Revo? Correct CV ball size, 12mm flange steps down to 6mm shaft, M5 MIP CVD Axle, Traxxas T-Maxx, E-Maxx (1) Shaft diameter? Ball diameter? Hole size through the center of ball? What two bearing sizes does it use in the knuckle? Last edited by sweli; 11-09-2011 at 03:09 PM. |
11-08-2011, 06:59 PM | #3 |
Anyone with a Tmaxx/Emaxx/Summit or Revo that is running MIP axle shafts? Could you measure the CV ball outside diameter, and the hole (barrel) diameter? |
