11-27-2011, 12:14 AM | #1 |
Newbie Join Date: Aug 2010 Location: sun valley
| swx chassis
is the swx chassis only for axial or will itfit to any crawler i wouldlike to get it
11-27-2011, 12:36 AM | #2 |
It can fit, but most chassis take into consideration the axles and how they mount up. Some axles are easier to swap into another chassis than others. I don't know enough about that chassis to give you an answer on how hard/easy it will be to swap. |
11-27-2011, 01:07 AM | #3 |
i got a used crawler the guy told me the axles are from tamiya txt or tlt i dont remeber but is oneof those two it has a sw3 chassis now but may be i can up to the swx
11-27-2011, 07:40 AM | #4 |
RCC Addict Join Date: Dec 2007 Location: Chuck Chuck Chuckin Rocks.
TLT? Yes it will fit just fine. Here's a link to Bender's vids. There are some of both the TLT and Axial's mounted up to the SWX. http://www.youtube.com/user/BenderCustoms There is also a TXT in there, but it's got them mounted to the SW2 if I remember correctly. Used as a super. JC Last edited by skid plate; 11-27-2011 at 07:47 AM. |
11-27-2011, 07:45 AM | #5 | |
The SWX is very similar to the SW3 the shock mounts are slightly higher up on the SWX. They both work well with TLT, Axial, Berg, and WK. Those are all I've tried Last edited by 666; 11-27-2011 at 07:48 AM. | |
11-27-2011, 07:48 AM | #6 |
Sorry, there now. JC |
11-27-2011, 12:13 PM | #7 |
thanks nice vid. now will that swx chassis be a lot better then the sw3 and if i get the one with the axial bars will they fit this one Ax30506 Axial Bender Customs SWX Chassis Kit [ax30506] - $64.99 : CKRC Crawlers, RC Rock Crawlers |
11-27-2011, 01:30 PM | #8 |
The progression from SW3 to SWX was a fine line. Always better if set up correctly. Bender has build threads on RCC that follow both the SW3 and the SWX. If you already have the SW3, try it out and then go to the SWX later. If you are getting either for the first time, I would go with the SWX kit and build it. Again, check out the build threads and think about what you want to do from there. If I may suggest also, purchase a star. It supports this site and it will also enable you to see the for sale section. Sometimes there are both of those chassis for sale there, along with other items you will want in the future. JC Last edited by skid plate; 11-27-2011 at 01:32 PM. |
11-27-2011, 04:14 PM | #9 |
how do i purchase a star
11-27-2011, 07:00 PM | #10 |
| After you log in, click on User CP on the header bar at the top of the page. You will be taken to the user control panel. On the lower left side you will see a link to Paid Subscriptions, click on it and decide what you want to purchase. JC |
11-27-2011, 07:45 PM | #11 |
ok i see thank you
