12-12-2011, 12:56 PM | #1 |
Rock Stacker Join Date: Nov 2010 Location: Champaign
| Narrowed Axial Axle
Searched and found a few threads where someone was showing a kit for narrowing the rear axial axle to a total of 8" from out side of tire to outside of tire. However those were all 2+ years ago and had some machined ends in the setup which i cant make. Does anyone have any tricks to narrow the rear axle or have a link to a kit to do this? Want to narrow the rear axle for a dually project because the tires stick out WAY to far with the f650 body. |
12-12-2011, 08:25 PM | #2 |
Just dug in an decided to design my own style to narrow the axle. I personally havent seen it done this way in my searches but im sure i cant be the first. Shall post pictures when its done.
12-13-2011, 06:43 PM | #3 |
Rock Crawler Join Date: Jul 2008 Location: Port Angeles
I ran into this exact issue when I built my dually. Heres the process I went through: 1. Cut off ends of axle housing even with the back of the screw bosses for holding knuckles on 2. File/grind/sand like a bandit till you can fit knuckles, or straight axle adaptors back on. You'll probably go all the way through in a few spots, not a big deal we'll address that later 3. Measure at least four times, then cut desired amount out of the middle of straight axles, hit the cut ends with a file just a bit. 4. Make a sleave from 3/16 brakeline roughly an inch long, get out your hammer and pound your axle halves into it. Its a dang near perfect press fit. Braze the ends of the sleave to the axle 5. Put a peice of heatshrink over the axles, then coat axles, ring gear liberaly with petroleum jelly. Mix up some plastic safe epoxy and apply to insides of axle housing. Stick the ring gear and axles into the case and press into the epoxy, the petroleum jelly will prevent you gluing things into a useless brick. Repeat for other half of housing when first is dry. Thats it lmk if you need any more info |
12-13-2011, 07:07 PM | #4 |
Pictures?
12-13-2011, 07:20 PM | #5 |
Build thread is in the 1.55 section. I didnt take any pics during the narrowing since I pretty well made it up as I went along, but you can see the final result in the thread
12-14-2011, 12:19 AM | #6 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
Not sure how narrow it would be, but what about using wraith short side axle shafts. That and some modded beef tubes might fly.
12-14-2011, 12:23 AM | #7 |
Got my shafts cut down tonight. Waiting on some custom machined parts to show the finished product. My plastic test piece is NOT pretty or picture worthy. But the way i designed it, the axles are 5/8" more narrow than stock. Looks PERFECT for the dually track width.
12-14-2011, 12:30 PM | #8 | |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
12-14-2011, 05:58 PM | #9 |
| Re: Narrowed Axial Axle
Here is a preview of the narrowed vs normal straight axle. 5/8" difference. Once the aluminum parts arrive ill post some detailed pictures and specs. |
12-14-2011, 06:05 PM | #10 |
you just narrowed one side?
12-14-2011, 06:23 PM | #11 |
Cut down a straight axle adapter for a test on how to make it work. It worked and i have some custom machined aluminum parts coming so i didnt feel the need to cut down another straight axle adapter when its getting replaced any how. BUT, its really tempting to do so i can see it under the truck done.
12-15-2011, 12:50 PM | #12 |
Have you thought of trying something like the long beef toobs? Just use the tubing itse;f to locate the chub? Then you could just cut the housing to the desired length and bolt the tube in with the C's/lockouts clocked wherever you want them? then you'd only have to chop the axle shafts and flat spot them to engage in the locker. Also curious as to how you are managing to attache the dually wheels in tandem? |
12-15-2011, 01:25 PM | #13 |
Using a pair of outlaw hobby's dually adaptors. A touch bit pricey but will look better than bolting the wheels together like most do. As for cutting the housing. Im trying to keep the housing intact because then i could reverse what i have done now by swapping back to a set of straight axle ends and new shafts. I would like it a little more narrow to match the body, but for what its for and how the track width is setup compared to a 1:1 scale dually its perfect. I just need to get my topkick body, using a f650 body i had laying around for my tmaxx, but the topkick looks like it should have a bit wider rear dually fender than the f650 which will then make everything perfectly scale. |
08-22-2012, 09:42 PM | #14 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
Here ya go CarLo.
