Thread: Venom creeper help
Old 12-28-2011, 06:46 PM   #1
Default Venom creeper help
I tried to use some jb weld to do my locking ring but within 2 mins of time running the rig it broke. what do i need to always be locked in? Also to put the rear lockouts on my set screws are all messed up and stripped. how am i able to get those out?
03ranger is offline   Reply With Quote
Old 12-28-2011, 09:20 PM   #2
Default Re: Venom creeper help
okay several suggestions
1. go to the creeper forum
2. read the tips and tricks section
3. read the on the creeper wagon thread
4. enjoy your creeper
as far as locking the diffs you can either use j.b weld on the spider gears or buy the availible lockers ( flm and rmdesignworks ) . you siad the setscrews are stripped out on your lockouts do you mean the factory lockout links or hr lockouts ?
viper6171 is offline   Reply With Quote
Old 12-29-2011, 03:17 PM   #3
on the factory lockouts
Old 12-29-2011, 03:45 PM   #4
on the set screws if they have a head on them use a dremel to cut a slot in them and use a flat blade screwdriver to remove them , if they are flush to the surface then you may have to drill them out if you can't find an easy-out that will fit .
Venom creeper help - Similar Threads
my venom creeper ebay007 Venom Creeper 2 10-19-2011 05:30 PM
Venom creeper ???????` VenomCreeper987 Newbie General 4 05-29-2011 11:41 AM
Venom Creeper 1.9s JuziTin Venom Creeper 0 04-13-2010 06:11 PM
