01-17-2012, 11:13 PM | #1 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
| Narrowed Wraith axles... the easy way
Hey all, Wanted to post up something I figured out on narrowing these wraith axles. I did 1 on my lathe a while back, but pondered an easier method, and came up with this. For those that don't know, this is being applied to my sportsman build. I will also be selling these housings on my site once I confirm they are strong. This mod takes 1 inch of width out of the housing. It is a hair narrower than a front XR10 axle. My build: CreationFab Resurrects La Licorne Fatale! My site: CreationFab - Crawler Accessories and Custom soldering Services Lets get started First thing I do is take the housing to my bandsaw, and cut as evenly as I can at the back side of the splines. I then cut the rest off at the edge of the lower link mount. Once I do this, I take the housing and end to my bench sander to make both sides perfectly square. Here are pics of both sides once cut Now that this is done, I get my materials. JB Weld, and some 11/32 brass tubing. The brass tubing is a tad smaller in diameter than the inner diameter of the wraith housing. In fact the long side is a bit tighter further in, and it fits nice and snug. The short side has a little wiggle, but the JB Weld fills that. After measuring, I cut the long side to about 80mm, and the short side to about 23mm. Cleaned up the burrs, and made sure they were fairly square Now I mix a little JB Weld. Took a piece of a small zip tie that was cut, and used it to apply the JB Weld to the inside of the tubes. As I inserted them, I twisted it, and slowly put it in. Had to pull it out, and apply some to the tube so it would fill the gaps. Took my time on this to make sure there was enough on the inside. I left axprox 8mm off the end. I wanted to make sure that the brass would come a hair from the back side of the bearing. Make sure to look into the housing, and see if the tube pushed any excess JB Weld in the way of anything, and clean the excess up. Now I applied some JB Weld to the remaining tube, and faces of the housing and splined end. Wanted to make sure all surfaces being bonded together, got enough. This axle is going to be a passenger drop on my sportsman, so I rotated the splined end back 1 spline to allow me some more caster. Stock, the housing has a seam that runs across the top and bottom from the injection mold process. The hole to keep the Chub in place, is lined up with this. So I just rotated it back to the next spline. I go and check on it every 10 mins or so to make sure the JB Weld hardens and the caster is exact. It does move some, so keep a careful eye on that. Hope this is helpful to some of you DYI'ers. I will post more once the JB Weld Dries. There will need to be some holes drilled since the tube covers some of them. |
01-18-2012, 12:03 AM | #2 |
| Re: Narrowed Wraith axles... the easy way
Saw this in the AX thread first, but to repeat, good job on it man. Looks super clean and near factory in the pics. I was kinda wondering what you had up your sleeve when you showed me the teaser this morning You gonna cut some XR axles shafts to length for these? |
01-18-2012, 12:36 AM | #3 |
No, I guess the HighlandCrawler Berg universals are direct drop in's |
01-18-2012, 01:37 AM | #4 |
| Re: Narrowed Wraith axles... the easy way |
01-18-2012, 06:28 AM | #5 |
Rock Crawler Join Date: Jun 2010 Location: KCRC
?.....so where do your links attach.
01-18-2012, 06:50 AM | #6 |
01-18-2012, 07:36 AM | #7 |
Looks good as well as "easy" to do. As to the "bits moving", when I used to do similar, I would stretch a wide rubberband to go from end to end to hold thiongs still. It would keep the splines from sliding off as well as twisting. I save the rubberbands from the post office, they work well. Just get the band started over one end of the axle, stretch to fit the rest of the axle and hook across the far end. Tweak alignments & walk away. |
01-21-2012, 11:53 AM | #8 |
RCC Addict Join Date: Jan 2010 Location: Vermont
Any more news on these?
02-01-2012, 01:13 PM | #9 |
Not at the moment. I am in the process of moving, and busy at work. So all the RC projects are on hold until I get my new garage and office setup.
03-27-2012, 04:44 PM | #10 |
RCC Addict Join Date: Mar 2009 Location: hawaii
Hey man, have you got any updates on this? Possibly a complete axle Setup with links am shocks all attached? I like the looks of this and would possibly like it on myscaler |
09-24-2012, 09:57 PM | #11 |
Rock Crawler Join Date: Jul 2007 Location: Rectalville
So how wide do these end up, hex to hex? I'd love to give this a shot, I need to match a set of OCP60's to the width of wheely king axles.
10-21-2012, 05:02 PM | #12 |
Newbie Join Date: Aug 2011 Location: Boise
Im interested as well to know what axle shafts you use. I plan on doing this to my wroncho. |
10-21-2012, 08:32 PM | #13 | ||
| Re: Narrowed Wraith axles... the easy way Quote:
Btw, thanks Chris the battery man for this write up!!! | ||
10-21-2012, 08:45 PM | #14 |
Thank you i was worried i would have to buy new axles. |
10-23-2012, 07:23 AM | #15 |
11-11-2012, 03:56 PM | #16 |
So those that have done this are they on comp rigs or scalers cause that's what im doing a set for and dont want to worry about them coming apart. |
11-11-2012, 07:48 PM | #17 |
Rock Stacker Join Date: Oct 2012 Location: Yakima
Update?
12-14-2012, 10:11 PM | #18 |
Pebble Pounder Join Date: Nov 2007 Location: Arnold
yes lets see the progress
12-16-2012, 07:19 AM | #19 |
Rock Stacker Join Date: Aug 2012 Location: ontario
Like, is this do up for rear axles?
03-10-2013, 03:45 AM | #20 |
Newbie Join Date: Jan 2012 Location: Indonesia
no update yet?
Narrowed Wraith axles... the easy way - Similar Threads | ||||
Narrowed Wraith Axle interest? | Chris_The_Battery_Man | General Crawlers | 33 | 01-23-2013 04:23 PM |
narrowed wraith? | heinie_21 | Axial Wraith | 15 | 10-19-2011 10:21 PM |
Cheap and easy Wraith hood hinges | Chris_The_Battery_Man | Axial Wraith | 9 | 09-10-2011 02:25 PM |
Easy way to widen axles? | JoeThePro | Tamiya XC/CC01 | 10 | 10-22-2010 03:52 PM |
Narrowed WK Axles | MetalMan | HPI Wheely King | 17 | 02-07-2008 01:08 AM |
