02-02-2012, 09:26 PM | #1 |
I wanna be Dave Join Date: Aug 2008 Location: Austin, TX, USA
| XR10 Axle Shafts in SCX10 Housings?
Hey folks, I've seen where people are making hybrid AXR10 axles, which are a wider version of the AX10 or SCX10 axle using XR10 universals. But what is involved in modifying XR10 universals to fit into a stock width SCX10 axle? Is it just a matter of shortening the shafts and grinding a flat spot for the locker? Or are there other problems with this setup? I'm building some SCX10 axles and would prefer not to have to buy Super 300s. Thanks! Tommy |
02-02-2012, 09:38 PM | #2 |
| Re: XR10 Axle Shafts in SCX10 Housings?
Hey Tommy, I have shortened XR10's in the front of my Sporty. I cut and machined new flats, but I would advise against that method. There just doesn't seem to be enough material to clamp onto even with no-slop lockers. They work, but eventually work free. I would cut in the middle, and weld them back together. You would also need XR-10 Chubs and knuckles. This will add just under .5" in width. Here is my setup: http://www.rccrawler.com/forum/axial...ml#post3383552 Have you thought about the RC4WD XVD's for the front? I just ran them in my SCX based scaler and was very happy with them. |
02-03-2012, 02:46 AM | #3 |
RCC Addict Join Date: Jan 2005 Location: Germany north
the cross-sectional area of the flat end and the round part of the shaft is nearly the same so you may just cut the shaft , heat up the end and press it flat w. a vise i think universal style shafts are the better ones for dust and dirt use |
02-03-2012, 07:02 AM | #4 | |
| Re: XR10 Axle Shafts in SCX10 Housings? Quote:
So did you ream out the internal "nubs" in the C's so they would fit over the axle ends? I'd love an off-the-shelf alternative, but I snap heavy duty pins in my CVDs all the time and I assumed the RC4WD stuff wouldn't hold up, either? That's not a bad idea! I wonder how much heat that would take? Might be something to look into... | |
02-03-2012, 07:13 AM | #5 |
| Re: XR10 Axle Shafts in SCX10 Housings? |
02-03-2012, 07:47 AM | #6 |
Tommy if you need help with this let me know. I can tig weld them at work.
02-03-2012, 07:56 AM | #7 | |
I've always steered clear of CVD's myself (pardon the pun). I decided to try them out since the Creeper guys all have great things to say about the RC4WD XVD's for their rigs. I also couldn't go wider on my class 2 without making it illegal. | |
02-03-2012, 09:21 AM | #8 | ||
02-03-2012, 09:23 AM | #9 | |
I just ordered a bunch of parts to replicate this setup, however it has become readily evident this mod is WAAAY beyond my capabilities. At least I found this out before I started hacking away and ruining the parts. Thanks for the input. | |
02-03-2012, 09:30 AM | #10 |
Use a piece angle with the V part down in a vise, then lay both parts in angle they will line up and be sqaure.
02-03-2012, 09:31 AM | #11 |
02-03-2012, 09:46 AM | #12 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
I used the shortened setup in my sporty all last season and had no trouble at all with the small flat in the locker. these are going in the scaler next, to many broken cvd pins for me... |
02-03-2012, 10:57 AM | #13 |
I wanna be Dave Join Date: Feb 2009 Location: Cowtown, USA
Hey Tommy....check out the write up I did on my local forum. XR10 Knuckles&C-HUBS on AX10/SCX10 axles... - WARCRC |
02-03-2012, 01:49 PM | #14 | |
My TCS order just came, and its kinda lookin' like 1/2 the order's going to have to go on WTT board. Such is life. | |
02-03-2012, 01:58 PM | #15 |
Quarry Creeper Join Date: Jun 2010 Location: Wheeling
my sportsman build has this explained.
02-03-2012, 06:05 PM | #16 |
I cut the shafts to length, then welded a bit of material on the ends, then ground the flats to fit.
02-03-2012, 06:15 PM | #17 |
Rock Crawler Join Date: May 2009 Location: Bellaire
If you buy a pair of long beef tubes,you don't have to cut the shafts.
02-03-2012, 07:43 PM | #18 |
Rock Crawler Join Date: Apr 2006 Location: Thorp WA, more sheep than men...
02-03-2012, 08:43 PM | #19 |
02-04-2012, 11:03 AM | #20 |
| Re: XR10 Axle Shafts in SCX10 Housings? yes,but there are some benefits to that too. However being that you are doing this for a SCX10,I'm sure you need to keep the wheels under the body somewhat for scale purposes. I would just go with a different wheel offset to make up the difference. JMO |
