02-22-2012, 10:05 AM | #81 |
| Re: RC Crawler Steering |
02-22-2012, 10:18 AM | #82 | |
| Re: RC Crawler Steering Quote:
Something like this: EDIT: I'm talking about the picture of your Super. The picture of the Wraith looks good, but would also benefit from a vertical line so people know what your are measuring off of. Last edited by C*H*U*D; 02-22-2012 at 10:24 AM. | |
02-22-2012, 11:03 AM | #83 |
Thanks for the input. I will work on a new picture this evening. Thanks! |
02-22-2012, 01:22 PM | #84 | |
RCC Addict Join Date: Aug 2010 Location: wherever paypal sais.
The same applies for vp's axial knucks as well.. only problem is those are reverse acherman knuckles. Meaning outside turns sharper than inside. For correct steering path we need the inner tire to turn sharper so they acually made them 15* in the wrong direction...the green lines on ur diamgram need to continue all the way to tierod mounting point. Whick will show were they are "supposed" to mount for correct acherman. only problem is that when you go past 0 and even 0 acherman knuckles the tend to rub the inside of the tires pretty bad. At least with the ax style high steer knuckles from what I have found. Those do work for correct acherman tho when applied in BTA steering setup. Jeremy this is a very insightful and informative thread. Big ups to you bro Last edited by kaneohecrawler; 02-22-2012 at 01:24 PM. | |
02-22-2012, 02:12 PM | #85 | ||
So, for a "correct ackermann" setup, these VP knuckles need to be run behind the axle. | ||
02-22-2012, 02:59 PM | #86 |
| Re: RC Crawler Steering I added a few comments (post 63)....if you want to use them, fine, if not, fine. It's your thread and it is rather helpful to many on this forum as is. |
02-22-2012, 03:24 PM | #87 |
02-22-2012, 03:35 PM | #88 |
02-24-2012, 03:32 PM | #89 |
RCC Addict Join Date: Nov 2005 Location: Utah
Remember this "tech article" about getting more power out of your steering. Not as informative as this thread but still a good one. RCCrawler.com- Your #1 source for Radio Controlled Rockcrawling! |
02-24-2012, 04:15 PM | #90 |
Rock Crawler Join Date: Oct 2011 Location: Co,Cork..Ireland
Yeah... Stickie this thread . . Sean . .. |
02-24-2012, 04:29 PM | #91 |
Yeah, I browsed through several of the tech articles before I wrote up the first few posts in this thread. I wanted to get a good format and I wanted to make sure it hadnt been covered before. BTW, this info will soon be a tech article on the main page. I just wanted to finalize a few things before Jason posted it. |
02-24-2012, 04:34 PM | #92 | |
Well done to you for all your hard work with lots of great infomation.... | |
02-24-2012, 06:23 PM | #93 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
post #84 nailed ackerman. I can't beleive that the only crawler that comes from the factory with a correct acerman set up is the xr-10. All others are not even zero. They are going the wrong direction. When would it ever be a good Idea for the inside wheel to not turn as sharp as the outside wheel. Check out the almost corrected bully ackerman.
02-24-2012, 06:52 PM | #94 | |
Rock Crawler Join Date: Jun 2011 Location: San Diego
Zero ackerman is when both the inside and outside wheel turn the same amount. Reverse ackerman is when the outside wheel turns more than the inside wheel. | |
02-24-2012, 07:06 PM | #95 |
| Re: RC Crawler Steering I updated the first post with a picture like yours....I also added a measurement of the caster on my super. |
02-24-2012, 07:07 PM | #96 |
| Re: RC Crawler Steering You are correct, I did not think that too many folks actually wanted to see a correct ackermann setup discussed. Do you think it is needed? Maybe just a short description and one of the pictures I posted earlier (which is similar to what you just posted)....
02-24-2012, 07:11 PM | #97 | |
Is that your bully? | |
02-24-2012, 07:24 PM | #98 |
yep |
02-24-2012, 07:28 PM | #99 |
This is crazy talk, everything is as described above. Can anyone else corroborate that? Last edited by opek; 02-24-2012 at 08:41 PM. |
02-24-2012, 07:33 PM | #100 |
| Re: RC Crawler Steering Interesting. Did you notice any changes in scrub when you switched from zero ackermann to your current setup? Are you talking about the AX10 or the XR10? The AX10 VP knuckles is what I posted in post #56 (and what kaneohecrawler quoted) and those are the "incorrect" ackermann knuckles (unless, of course, you run them BTA). |
RC Crawler Steering - Similar Threads | ||||
my crawler has very little steering | 350oshin | Axial SCX-10 | 21 | 09-08-2011 01:52 AM |
My first crawler, 4 wheel steering | Slowsteve | Axial Wraith | 2 | 08-01-2011 01:37 PM |
How can i make my crawler king have 4 Wheel steering??? | HPI sleeper | HPI Wheely King | 8 | 12-15-2010 06:37 PM |
why does the steering on my clod crawler suck?? | chino | Tamiya Clod Buster | 8 | 12-29-2006 11:23 AM |
