02-18-2012, 08:06 AM | #1 |
Quarry Creeper Join Date: Mar 2006 Location: Australia
| Tzi's dual motor winch how-to
I mentioned in another thread that I had made a wireless dual motor winch for a customer and a few people wanted to know how, so I've quickly made another one and taken photos for a how-to. First up, you'll need two identical RC4WD Bulldog 9300XT Winches. If you want the final winch to have a wireless controller, then its cheaper to buy one of them as a wireless winch, rather than buy two normal ones and the wireless addon kit. 1x Z-E0021$34.99 1x Z-E0015 $59.99 OR 2x Z-E0021$34.99 Start by unscrewing the winch from the mounting plate underneath. Then, unscrew the two screws in the top plate on the shorter side and take that off. Loosening the grub screw in the thicker end. Remove the winch drum Do the same to the other winch Remove the top plate on the second winch Now this is the hardest bit... Take one winch drum and cut/grind/remove the shaft off the end, Drill ALL the way through from one side to the other, taking care to drill straight. If you have a lathe, now is a good time to use it ;) NOTE: You will need to drill a new hole and grub screw to attach your winch rope, as the existing hole and grub have been used to hold the second motor shaft. As I did this build/shoot in a limited amount of time, I'll have to leave that up to your imagination. Now, attach the drum to the motor on the side that the top bar is attached to. Bolt the second motor onto the drum being particular to line up the flat spot. You can then rotate the motor till the top plate lines up, put the screws in. Be careful lining this part up, as the screws can easily strip in the cast metal. Screw the mounting plate back on... and your almost done Now... you may notice that the wires are coming out the front on one side. This can be very easily fixed (although its a bit fiddly) by simply pulling the gearbox out of the casing, and threading the wires back through the other hole. Wire the motors together in parallel, and connect them to the winch controller. NOTE: When wiring the motors together, be sure that the motors are rotating in the correct direction, and not fighting against each other... otherwise you'll find out real quick which one was stronger So, lets consider what you get for $95... 1x Dual Motor winch 1x Wireless controller 1x Standard controller 2x Winch hooks 2x Spare gearboxes (each winch comes with a bonus gearbox) 1x Spare mounting plate/fairlead roller 1x Spare spool, and some spare winch body parts |
02-18-2012, 08:07 AM | #2 |
| Re: Tzi's dual motor winch how-to
I also found some pics of the first one I build for a customer. The red stuff on the wireless controller is plasti-dip for waterproofing. I tested this particular winch lifting weights in a vertical pull. I suspect the numbers would be higher on a static linear pull. Not a bad figure for a stock controller Its worth noting that RC4WD are covering their behinds (and who could blame them) by saying their winch is only rated to 1.5kg. Its a very conservative figure, but it means that customers will not complain when anything goes wrong. The actual stall rate on these is closer to 5kg, however the stock controller may not agree (soon to be tested). As with all mechanical parts, your milage may vary. The gears are very small, and any grit/dirt/gunk in the gearbox will cause premature failure. That said, replacement gearbox/motors from RC4WD are only about $10 I have had several good winches that seem to be indestructable, and some that give up quickly. Its always the gearbox that goes, rarely the motor. I'll be doing some testing shortly (with video) to check out the stall rate of single, and dual motor winches at various voltages and with different controllers. Last edited by Tzi; 02-18-2012 at 08:22 AM. |
02-18-2012, 08:20 AM | #3 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
Nice, thx for the write up. Kinda what I was thinking in my head. Would be a bit big for smaller build but not out of place on a 1/8 scale
02-18-2012, 08:24 AM | #4 |
Its only a little bit longer than a single motor winch. I should do a side by side shot. If your using an RC4wd winch, chances are your not going for 100% scale looks anyway. 3racing winch has the same gearbox/motor and looks like a replica, but its a little bit more fiddly to do a dual motor as the top plate is not symetrical and requires cutting. |
02-18-2012, 08:37 AM | #5 |
Pebble Pounder Join Date: Jun 2007 Location: Sacramento
Too cool thanks for taking the time to do this!
02-18-2012, 08:59 AM | #6 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
just kinda gandering at this tzi, could you make a dummy winch out of the spares? looks like the spreader plate and a little modification to the spool and you'd be set?
02-18-2012, 09:45 PM | #7 |
Something like this??
02-18-2012, 09:46 PM | #8 |
Comparison between single motor and dual motor...
04-20-2012, 03:12 PM | #9 |
Newbie Join Date: Apr 2012 Location: Wilmington
Video going up soon?
08-29-2013, 05:24 PM | #10 |
Pebble Pounder Join Date: Nov 2012 Location: madera
where is the video this f..... bad ass man so on the motors you put the 2 red wiers togerther and the to BL togerther and it will work with the wire less box they come with ?
08-30-2013, 12:13 AM | #11 |
I think the wires are not same color paired, it's red-black paired from memory but I think it depends on which way up the motor was when the factory soldered on the wires Best test each side for rotation to make sure the wiring is right before you solder them together |
08-30-2013, 09:50 AM | #12 |
ok coo this is a nice set up you did man i love it . ok so the wireless controller can run the 2 motors and it will not bunr out ?
08-30-2013, 09:53 AM | #13 |
i would love to see a vidoe if you have one of it working ? |
08-31-2013, 01:03 PM | #14 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
Cool! I always wondered if this was possible.
08-31-2013, 10:42 PM | #15 |
RCC Addict Join Date: Dec 2011 Location: Australia Queensland!
Very cool mate. I would love to see a video of it going.
12-03-2013, 11:06 AM | #16 |
Pebble Pounder Join Date: Jun 2013 Location: NKY
Any luck with a video? Also any more tests on a linear pull?
12-03-2013, 11:58 AM | #17 |
Quarry Creeper Join Date: Nov 2012 Location: Michigan
Great write up brother. Might have to try my hand at this now!
Tzi's dual motor winch how-to - Similar Threads | ||||
Dual motor mount good or bad? | TW31 | Axial Wraith | 1 | 02-10-2012 07:44 AM |
Dual motor mount....Anyone tried it yet? | 93-12smoke | Axial SCX-10 | 9 | 08-19-2011 07:02 PM |
Airtronics M11 Settings for Dual Motor Dual Servo Crawlers | John Hallman | Electronics | 7 | 10-07-2010 11:34 PM |
Hot Racing Motor Mount Hits Spur Mount HELP!! | RevoRacer | Axial AX-10 Scorpion | 3 | 05-08-2008 06:06 PM |
dual motor mount for ax10? | stikkimikki87 | Axial AX-10 Scorpion | 3 | 02-29-2008 11:15 PM |
