02-20-2012, 10:48 AM | #1 |
Rock Crawler Join Date: Jun 2011 Location: San Diego
| Help me understand, explain, and fix or solve torque twist
There are all sorts of rigs with TT from the MRC ,to the creeper, to all those awesome shaft driven supers! Help me understand and explain TT. http://www.rccrawler.com/forum/axial...-new-post.html |
02-20-2012, 10:57 AM | #2 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
| Re: Help me understand, explain, and fix or solve torque twist
Maybe this will help; Torque is the same as Force, only Force is a push or pull and Torque is a twist. If we want to calculate Acceleration we fall onto the simple equation: F = MA or Force = Mass * Acceleration Rearranged for A: A = F / M or Acceleration = Force / Mass A simple observation here is that more Force or less Mass will allow you to Accelerate faster. But we all know that one. :-) Torque gets converted into Force ( twist gets converted into push ) when Torque applied to your axel turns your tires and the tires act on the ground. The ground is stationary, so the car must move forward. Converting engine Torque to Force allows me to point out that Torque accelerates your car, not Power. Power is the amount of work per unit of time. |
02-20-2012, 11:27 AM | #3 |
How does that translate into the way link triangulation affects TT?
02-20-2012, 11:43 AM | #4 |
Quarry Creeper Join Date: Jun 2010 Location: Wheeling
| Re: Help me understand, explain, and fix or solve torque twist |
02-20-2012, 12:16 PM | #5 |
Quarry Creeper Join Date: Nov 2011 Location: Kentucky
Mirror your tranny and switch to a 4 link suspension preferably with a sorta wide mount points on the axles for your upper links. Helped me tremendously.
02-20-2012, 01:13 PM | #6 |
A simple way to look at it is, with a ring & pinion axle (like all the rigs you listed, but NO MOA's!!) the drive-shaft & pinion are trying to climb the ring gear in the diff. Since you're also trying to accelerate the axle & wheels (which are likely weighted) you have 2 forces fighting each other. -One force is the twist down the length of the rig caused by the rotating drive-shaft. -One force is across the rig caused by the axle. When you accelerate the rig, the drive-shaft is trying to accelerate the axle but there is some resistance (object at rest tends to stay at rest......) so some extra power is wasted by rocking the rig over (torque twist). Triangulation spreads the loads wider giving more leverage of the chassis against the axle, thus helping reduce the signs of torque twist. Dropping wheel weight would help as well since there would be less resistance to acceleration (or deceleration). Does that help any? |
02-20-2012, 01:41 PM | #7 |
02-20-2012, 01:54 PM | #8 |
Newbie Join Date: Jan 2012 Location: Hunterdon County
i like torque twist ;)
02-20-2012, 02:52 PM | #9 |
| Re: Help me understand, explain, and fix or solve torque twist Its still there, just in a much smaller amount because of the gear reduction. The greater the ratio, the less twist you will have. If you had a worm gear axle with the same amount of reduction as a garden variety ring and pinion, the twist would be the same. I've never considered the "gears are trying to climb" idea as a very good explanation of TT. Realizing that you have rotational force originating from a base that is not solidly anchored (chassis) and applying it to something that is more stationary (axle) and its pretty easy to understand that something has to move. The easier it is for that rotational force to transfer power (gear reduction) the less effect the twisting motion will be evident. A properly tuned 4 suspension will mechanically and preemptively counteract or redirect that force but not eliminate it. When enough force is applied, TT will always show up eventually. Last edited by Duuuuuuuude; 02-20-2012 at 02:55 PM. |
02-20-2012, 02:56 PM | #10 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
What he said. |
02-20-2012, 03:10 PM | #11 | |
| Re: Help me understand, explain, and fix or solve torque twist Quote:
02-20-2012, 03:22 PM | #12 | |
| Re: Help me understand, explain, and fix or solve torque twist Quote: So what I'm getting from this is there are two torques in play. The first "Troll" is going to be where the roll axis intersects the plane perpendicular to the output shaft on the transmission. The other "Tout" is going to be in the center of the output shaft itself. Varying the distance between these two points will change how much mechanical advantage Tout will have when it is applied to Troll. Would raising the roll axis make the lever arm coming from the trans output longer? Would that reduce the appearance of TT? | |
02-20-2012, 06:03 PM | #13 | ||
02-20-2012, 06:13 PM | #14 | |
Ask anyone who's ever ran a floor buffer...the greater the resistance between the pad and the floor, the greater the chance of you getting tossed on your ass. Not because of how the pad is driven, but because of how much the floor resists the rotational force of the pad. Because the floor is anchored to the earth, and the buffer is anchored (loosely) to you, the floor isn't likely to move. Last edited by Duuuuuuuude; 02-20-2012 at 06:17 PM. | |
02-20-2012, 06:16 PM | #15 |
| Re: Help me understand, explain, and fix or solve torque twist That whole mechanism is causing a major portion of the torque twist. If you were to compare a stock LCC and a stock AX10, which one has more torque twist? They both have driveshafts...
02-20-2012, 06:19 PM | #16 | |
Like I said earlier, build a worm gear axle with the same reduction as an average ring and pinion setup and the TT will be nearly the same. | |
02-20-2012, 06:21 PM | #17 |
Harumph.
02-20-2012, 06:22 PM | #18 | |
02-20-2012, 06:23 PM | #19 |
02-20-2012, 06:26 PM | #20 |
| Re: Help me understand, explain, and fix or solve torque twist A roto-tiller doesn't apply force to the ground in the same manner. Lay it on its side and it does. |
Help me understand, explain, and fix or solve torque twist - Similar Threads | ||||
What is Torque Twist (TT) and how to fix it. | opek | Axial AX-10 Scorpion | 86 | 07-16-2013 09:22 PM |
Torque twist | abbott90 | Losi Mini-Rock Crawler | 4 | 04-02-2011 05:47 AM |
help!-- Torque twist | Tom94offroaduk | Newbie General | 24 | 03-03-2011 04:46 PM |
can someone explain stall torque | camobob | Electronics | 7 | 03-17-2010 09:27 AM |
torque twist | rockmike | Tamiya TLT Crawlers | 82 | 06-06-2007 12:26 AM |
