03-04-2012, 08:52 AM | #1 |
Quarry Creeper Join Date: Sep 2010 Location: too close to LRC.... Jealous????
| suspension tech 101.... short course vs. crawler
Let's discuss suspension setups, and differences in the way you setup a shortcourse truck vs. your comp rig and everything in between....
03-04-2012, 07:25 PM | #2 |
| Re: suspension tech 101.... short course vs. crawler
Seriously? That's like asking how you ride a horse compared to how you fly a plane.
03-04-2012, 07:27 PM | #3 |
| Re: suspension tech 101.... short course vs. crawler |
03-04-2012, 07:29 PM | #4 |
03-04-2012, 07:34 PM | #5 |
03-04-2012, 07:36 PM | #6 |
03-04-2012, 07:47 PM | #7 |
Hmmmm. I'm not following. Airplanes wouldn't have teeth, they don't need them. Beer maybe, but not teeth. Wait. I get the reference. I agree!! The Jeffersons are hilarious. |
03-04-2012, 07:49 PM | #8 |
03-04-2012, 11:56 PM | #9 |
Rock Crawler Join Date: Feb 2011 Location: Courtenay
You guys are about as serious as a case of E.D.S. Keep it up boys. I'm still laughin! Nothin to say on the thread topic. Just to be clear. Been studying 4-link tuning for a month now. more confused than eva! |
03-05-2012, 07:17 AM | #10 |
Actually a comparison of these two types of vehicles would be interesting. It's why I don't like to use the term squat, and prefer thinking of our situation as suspension jacking.
03-05-2012, 07:45 AM | #11 |
| Re: suspension tech 101.... short course vs. crawler To be serious, there is only a couple of things that cross over that I can think of. But still, we're comparing two rigs that couldn't be any more dissimilar unless one of them were running square wheels.
03-05-2012, 10:56 AM | #12 |
Pebble Pounder Join Date: Mar 2011 Location: Aurora, CO
Suspension design differs between them enough to where it's hard to make any comparison. Your typical crawler is a solid axle 4-link or leaf spring setup where the SC truck is a double wishbone independent arm setup. Terrain makes a world of difference in each realm for general setup. Spring rate, damping pack and rebound, shock angles, link angles, arm leverage, ride height, sprung and unsprung weight etc. All these are application specific for proper tuning. A more relavant comparison would end up being comparing suspension setup between a shafty rig and a MOA. Even those differ some due to overall unsprung weight. Marcus |
03-05-2012, 01:27 PM | #13 | |
| Re: suspension tech 101.... short course vs. crawler Quote:
03-05-2012, 09:17 PM | #14 |
I wanna be Dave Join Date: Oct 2008 Location: I miss Rowdy
10-04-2012, 08:27 PM | #15 |
lets revitalize this.... the reason for asking is I understand the difference in suspension setups as far as 4 link, 3 link, straight axle or independent etc. I am asking the difference is how you setup a shock based on terrain and what you do with the rig...like say you have something like a wriath, 4 links, staight axle, and you want to go fast, but crawl decent as well... what differences would you make in the spring rates, shock oil, etc to make it perform.... or you have a 4 linked straight axle desert truck, what would you base the suspension setup off of on that? shock angle? how is it figured on where the shocks are mounted? I guess I am asking if its all trial and error? or if you have certain basis you use for setups? |
10-04-2012, 09:51 PM | #16 |
Quarry Creeper Join Date: Mar 2009 Location: Grande Prairie, AB, Canada
| http://www.thirdgen.org/techboard/su...readsheet.html I know these spread sheets are ment for full size but should work for rc also....... Sent from my GT-I9100M |
10-04-2012, 10:15 PM | #17 |
For a good all around setup you'd have to find a happy medium between the two. Pick the one that is most important to you and start working your way towards the other one.
10-05-2012, 12:56 AM | #18 |
no talent hack Join Date: Feb 2007 Location: Redwood City
If you know how to set up a short course truck in terms of controlling left to right chassis roll, you can setup a crawler and vise versa. If you take the rear of any independent suspension vehicle and look at left to right, it translates directly to a crawlers link geo front to back. Your a arm acts the same way as a lower link, and your camber link would be the upper link. Camber change is the same as pinion angle change, longer camber links effect the car the same way as a longer upper would affect a crawler, and so on. It's just a matter of left to right movement of a sc behaving the same way as front to back movement and weight transfer on a crawler. I have been running a lot of pro level sc and mod buggy lately and what I know from crawlers directly translated over to the race vehicles. It definitely allowed me to lessen the learning curve and progress much faster |
10-05-2012, 06:12 AM | #19 |
well I just know when I setup a truck, I am either just trying to match a wheelbase, or wherever the links I currently have will fit (LOL), as for pinion angle, I just try to make it as straight as possible toward the trans....or try to be parallel with lower links... but how do you figure shock angle, oil weght, spring rate, holes in diaphram etc..... I just use trial and error, and in general want the truck to sit around half travel.... but I'd really like to see what others base it off of....
suspension tech 101.... short course vs. crawler - Similar Threads | ||||
Thunder Tech Racing Short Course? | Zeus.:God | Non Crawler RC's | 7 | 02-23-2012 11:34 PM |
Suspension 101 | jammindriver | General Crawlers | 2 | 07-11-2011 06:52 AM |
Suspension (101 for crawling) | jason46 | Team Losi Comp Crawler | 4 | 01-09-2011 05:03 PM |
Suspension 101 ? | Inconceivable | Losi Mini-Rock Crawler | 15 | 12-14-2009 04:43 PM |
Droop Suspension 101 | morg59jeep | Losi Mini-Rock Crawler | 6 | 11-15-2008 08:32 PM |
